Use of UART5 for RS485 communication IMX7D
Hello
i tried to use the UART5 to open a halfe duplex communication with an RS485 device.
the UART is on HArdware side adapted to the RS485 over an external driver.
first I tried to open the UART5 like the example in this thread
https://developer.toradex.com/knowledge-base/how-to-use-uart
but it faild at this point
*port = CreateFile(TEXT("CoM5:"), GENERIC_READ | GENERIC_WRITE, 0, NULL, OPEN_EXISTING, FILE_FLAG_WRITE_THROUGH, NULL);
if (*port == INVALID_HANDLE_VALUE)
    printf("Error Opening CoM Port\n");
    return FALSE;
which fault have i done to open this port.
additional question is which modifikation i have to do to run the UART5 as RS485 in halfe duplex mode
thanks for the Help
Dear @blaviken
By default, there is no driver loaded for UART5. To activate the additional serial port, you need to modify the following registry setting:
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\COM5]
Dll="serial_imx7.dll"
Make sure to save the registry.
Regards, Andy
Dear @andy.tx
thanks for your Help.
i changed the registry and now it works thanks.
Regards, Blaviken
Dear @andy.tx
Regards, Blaviken
