Hi all,
I tried to build a custom image with ptxdist (due to legacy reason I cannot use Open Embedded) for an apalis iMX6q IT module.
I used the configuration “apalis_imx6_nospl_it_defconfig” because my module is IT. Furthermore I saw that the “apalis_imx6_defconfig” does not support “u-boot.imx”.
The image installation failed; no error during the process but the module wasn’t able to startup. I had to reset it manually.
So far my question is: is correct to build an image with the configuration set in “apalis_imx6_nospl_it_defconfig” for that kind of module? Should I use the standard “apalis_imx6_defconfig” with “u-boot.img”?
Many thanks,
Best regards.
Massimo
