Use Ixora's SATA port for PCIe
To enable a second PCIe on the Ixora carrier board by disabling the on-SOM WiFi and SATA, you will need to make changes to the device tree. Here are the steps to modify the device tree for the Apalis iMX8 SOM on the Ixora carrier board:
  1. Disable the On-SOM WiFi:
    • Locate the device tree node for the WiFi module and disable it. This is typically done by setting the status property to disabled.
  2. Disable the SATA Interface:
    • Similarly, locate the device tree node for the SATA interface and disable it by setting the status property to disabled.
  3. Enable the Second PCIe Interface:
    • Find the device tree node for the second PCIe interface and enable it by setting the status property to okay.
Here is an example of how you might modify the device tree:
&pcie1 {
    status = "okay";
&pcie2 {
    status = "okay";
&wifi {
    status = "disabled";
&sata {
Steps to Apply the Changes:
  1. Locate the Device Tree Source (DTS) File:
    • The device tree source files are usually located in the arch/arm64/boot/dts/freescale/ directory of your Yocto build environment.
  2. Edit the DTS File:
    • Open the appropriate DTS file for the Apalis iMX8 SOM and Ixora carrier board in a text editor and make the changes as shown above.
  3. Rebuild the Device Tree Blob (DTB):
    • After making the changes, rebuild the device tree blob by running the appropriate build commands in your Yocto environment.
  4. Deploy the New DTB:
    • Copy the newly built DTB file to the boot partition of your device.
  5. Update U-Boot Environment:
    • Ensure that U-Boot is configured to load the new DTB file.
  6. Reboot the System:
    • Reboot the system to apply the changes.
Example Commands:
# Navigate to the Yocto build directory
cd /path/to/yocto/build
# Edit the device tree source file
vim arch/arm64/boot/dts/freescale/imx8-apalis-ixora.dts
# Rebuild the device tree blob
bitbake -c compile -f virtual/kernel
bitbake -c deploy virtual/kernel
# Copy the new DTB to the boot partition
cp /path/to/build/tmp/deploy/images/apalis-imx8/imx8-apalis-ixora.dtb /media/boot/
# Update U-Boot environment if necessary
fw_setenv fdt_file imx8-apalis-ixora.dtb
# Reboot the system
reboot
Please refer to the Apalis iMX8 and Ixora carrier board manuals for specific details on the device tree nodes and properties. If you encounter any issues, consult the Toradex community forums or support for further assistance.
Help to integrate a custom kernel into a Torizon Core Image.
