I’m working on a project that needs to have the I2C2 bus on the Aster board available on Linux.
From the datasheets of the Colibri i.MX7 SOM and the Aster board I’ve noticed that the PINs needed for the I2C2 bus are configured by default to be used for an SPI bus (ecspi3 on the Aster board).
So I’ve edited the device tree, removing the definition of the SPI bus that was using the same PINs and configuring the new I2C2 bus. This is the patch I’ve implemented:
diff --git a/arch/arm/boot/dts/imx7-colibri-aster.dtsi b/arch/arm/boot/dts/imx7-colibri-aster.dtsi
index 6576ef5..0dddde2 100644
--- a/arch/arm/boot/dts/imx7-colibri-aster.dtsi
+++ b/arch/arm/boot/dts/imx7-colibri-aster.dtsi
@@ -79,30 +79,11 @@
-&ecspi3 {
- fsl,spi-num-chipselects = <2>;
- cs-gpios = <
- &gpio4 11 GPIO_ACTIVE_HIGH
- &gpio4 23 GPIO_ACTIVE_HIGH
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_ecspi3 &pinctrl_ecspi3_cs &pinctrl_gpio5>;
+&fec1 {
- spidev0: spidev@0 {
- compatible = "toradex,evalspi";
- reg = <0>;
- spi-max-frequency = <23000000>;
- spidev1: spidev@1 {
- reg = <1>;
-&fec1 {
+&i2c2 {
diff --git a/arch/arm/boot/dts/imx7-colibri.dtsi b/arch/arm/boot/dts/imx7-colibri.dtsi
index 16505eb..33f4bda 100644
--- a/arch/arm/boot/dts/imx7-colibri.dtsi
+++ b/arch/arm/boot/dts/imx7-colibri.dtsi
@@ -101,14 +101,6 @@
arm-supply = <®_DCDC2>;
-/* Colibri SPI */
-&ecspi3 {
- fsl,spi-num-chipselects = <1>;
- cs-gpios = <&gpio4 11 GPIO_ACTIVE_HIGH>;
- pinctrl-0 = <&pinctrl_ecspi3 &pinctrl_ecspi3_cs>;
&fec1 {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&pinctrl_enet1>;
@@ -237,6 +229,12 @@
+&i2c2 {
+ clock-frequency = <100000>;
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_i2c2>;
&i2c4 {
@@ -485,20 +483,6 @@
- pinctrl_ecspi3_cs: ecspi3-cs-grp {
- fsl,pins = <
- MX7D_PAD_I2C2_SDA__GPIO4_IO11 0x14
- pinctrl_ecspi3: ecspi3-grp {
- fsl,pins = <
- MX7D_PAD_I2C1_SCL__ECSPI3_MISO 0x2
- MX7D_PAD_I2C1_SDA__ECSPI3_MOSI 0x2
- MX7D_PAD_I2C2_SCL__ECSPI3_SCLK 0x2
pinctrl_flexcan2: flexcan2-grp {
fsl,pins = <
MX7D_PAD_GPIO1_IO14__FLEXCAN2_RX 0x59
@@ -531,6 +515,13 @@
+ pinctrl_i2c2: i2c2-grp {
+ fsl,pins = <
+ MX7D_PAD_I2C2_SDA__I2C2_SDA 0x4000007f
+ MX7D_PAD_I2C2_SCL__I2C2_SCL 0x4000007f
pinctrl_i2c4: i2c4-grp {
fsl,pins = <
MX7D_PAD_ENET1_RGMII_TD3__I2C4_SDA 0x4000007f
I’ve connected to the Aster board a device (an accelerometer) to the I2C2 PINs but I’m not able to detect it from userspace:
$ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I’ve tested the same device on the I2C4 bus (removing the touch screen of the Toradex capacitive display that will be needed for this project) with this result:
$ i2cdetect -y 3
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 1f
20: -- 21 -- -- -- -- -- -- -- -- -- -- -- -- -- --
This last result is what I’m expecting from this particular device.
Is it possible to use those PINs as I2C with the Aster board?
Thanks,
Roberto
