I forgot my login credentials.There is no forget password option available.
I want to connect Capacitive Touch Display 10.1 Inch LVDS to Apalis Evaluation Board that contains Apalis iMX8.
Now I want to use external SD card to set up the Torizon OS.What should be the specification of the SD card that I should buy?
How should I do that ?
Hi @Jintu ,
What recognition are you talking about?
Please tell us the steps you followed and the error you are getting.
Hi @sahil.tx ,
I have connected USB01_CL to my laptop.Ethernet connection was provided to the board.
I have given the following commands.
jintu@jintu-george-renji:~$ ssh torizon@apalis-imx8-072xxxx
ssh: Could not resolve hostname apalis-imx8-072xxxx: Temporary failure in name resolution
jintu@jintu-george-renji:~$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 0c45:6d1a Microdia Integrated_Webcam_HD
Bus 003 Device 002: ID 27c6:639c Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC
Bus 003 Device 043: ID 25a7:fa67 CX 2.4G Receiver
Bus 003 Device 004: ID 8087:0026 Intel Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Hi @Jintu ,
You can see the error clearly
"Could not resolve hostname apalis-imx8-072xxxx:"
The network does not know what is apalis-imx8-072xxxx or simple it can not resolve this name to address.
Instead, try using IP address
Hi @Jintu,
Anyways, you will not be able to login because you have already lost your password.
As guided earlier, please re-flash the module using the step by step procedure provided in the article.
Hi @sahil.tx ,
I have Installed Torizon OS again by putitng my Apalis iMX8 in Recovery Mode.I have created username and password succesfully.But when I try to connect after some time using hostname but I can’t.Then I tried using IP address.It is getting refused.
jintu@jintu-george-renji:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback xx:xx:xx:xx:xx:xx brd xx:xx:xx:xx:xx:xx
inet xxx.x.x.x/x scope host lo
valid_lft forever preferred_lft forever
inet6 ::x/xxx scope host
2: enp44s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether xx:xx:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff
3: wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet xxx.xx.x.xx/xx brd xxx.xx.xx.xxx scope global dynamic noprefixroute wlp0s20f3
valid_lft 160712sec preferred_lft 160712sec
inet6 xxxx::xxxx:xxxx:xxxx:xxxx/xx scope link noprefixroute
jintu@jintu-george-renji:~$ ssh torizon@xxx.xx.x.xx
ssh: connect to host xxx.xx.x.xx port 22: Connection refused
jintu@jintu-george-renji:~$ ^C
How can I solve this.I am new to Toradex and Linux Terminal. It would be really helpful if you can explain in detail.
Hi @Jintu,
You need to use the ip address of your device where you want to login.
Here it should be the ip address of your Apalis iMX8
