Hi all,
I need to do some modifications in the 5.4 kernel provided by the 5.0 BSP. Usually (for other SOM) I use devtool modify <kernel-img> and modify/commit my changes in the yocto kernel recipe.
Here I got :
ERROR: Execution of '/home/yoctouser/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.47+gitAUTOINC+9e7307657f+gitAUTOINC+9e7307657f-r1/devtooltmp-fwwugw2f/temp/run.do_preconfigure.546430' failed with exit code 2:
/home/yoctouser/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.47+gitAUTOINC+9e7307657f+gitAUTOINC+9e7307657f-r1/devtooltmp-fwwugw2f/temp/run.do_preconfigure.546430: 119: /home/yoctouser/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.47+gitAUTOINC+9e7307657f+gitAUTOINC+9e7307657f-r1/devtooltmp-fwwugw2f/temp/run.do_preconfigure.546430: cannot open /home/yoctouser/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.47+gitAUTOINC+9e7307657f+gitAUTOINC+9e7307657f-r1/devtooltmp-fwwugw2f/workdir/defconfig: No such file
WARNING: exit code 2 from a shell command.
ERROR: Logfile of failure stored in: /home/yoctouser/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.47+gitAUTOINC+9e7307657f+gitAUTOINC+9e7307657f-r1/devtooltmp-fwwugw2f/temp/log.do_preconfigure.546430
Log data follows:
| DEBUG: Executing shell function do_preconfigure
So, my defconfig is not found by devtool but I can build without error the 5.4 kernel and any yocto image provided by toradex, using bitbake.
After looking carefully in my workdir folder when I use the devtool modify linux-toradex command, I saw a defconfig file added and quickly removed…
Is this nominal in your BSPs ?
are you using this devtool functionnality ?
Thank you for your time,
Arthur
