Hi everyone:
I have an Colibri iMX6 expansion board that has wl18xx connected to usdhc2.
My image is based on meta-toradex-nxp.git, Rocko branch, linux-toradex_4.9-1.0.x
When booted up, the kernel gives me
[ 2.000020] sdhci-esdhc-imx 2194000.usdhc: sdhci_pltfm_init failed -12
[ 2.014988] sdhci-esdhc-imx: probe of 2194000.usdhc failed with error -12
I put this in my device tree.
mmc2_pwrseq: mmc2_pwrseq {
compatible = "mmc-pwrseq-simple";
reset-gpios = <&gpio3 24 GPIO_ACTIVE_LOW>, /* WiFi Bluetooth enable pins */
<&gpio3 23 GPIO_ACTIVE_LOW>;
&usdhc2 {
label = "SDIO";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usdhc2>;
mmc-pwrseq = <&mmc2_pwrseq>;
keep-power-in-suspend;
enable-sdio-wakeup;
non-removable;
cap-power-off-card;
no-1-8-v;
#address-cells = <1>;
#size-cells = <0>;
wlcore@0 {
compatible = "ti,wl1835";
reg = <0x2>;
interrupt-parent = <&gpio3>;
interrupts = <25 IRQ_TYPE_EDGE_RISING>;
usdhc {
pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17069
MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10069
MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17069
MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17069
MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17069
MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17069
MX6QDL_PAD_EIM_D25__GPIO3_IO25 0x13059
MX6QDL_PAD_EIM_D24__GPIO3_IO24 0x13059
MX6QDL_PAD_EIM_D23__GPIO3_IO23 0x13059
The same device tree works for Morty branch.
Menuconfig:
MMC_SDHCI [=y]
MMC_SDHCI_ESDHC_IMX [=y]
Even when I only put this in device tree, it still gives me the same error.
&usdhc2 {
Anybody know what might be the problem? Thanks
