A USB3.0 GbE adapter AX88179 is connected to TK1’s USBH4 port.However, the bandwidth test shows it is less than 1Gbps. TK1 is configured to maximum performance by setting scaling_governor . The adapter can be almost 1Gbps when connected to X86 Ubuntu.
root@apalis-tk1:~# iperf3 -c 192.168.20.111
Connecting to host 192.168.20.111, port 5201
[ 5] local 192.168.20.112 port 59233 connected to 192.168.20.111 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.04 sec 26.2 MBytes 212 Mbits/sec 0 143 KBytes
[ 5] 1.04-2.02 sec 26.2 MBytes 223 Mbits/sec 0 143 KBytes
[ 5] 2.02-3.02 sec 26.2 MBytes 221 Mbits/sec 0 143 KBytes
[ 5] 3.02-4.01 sec 26.2 MBytes 223 Mbits/sec 0 144 KBytes
[ 5] 4.01-5.01 sec 26.2 MBytes 221 Mbits/sec 0 144 KBytes
[ 5] 5.01-6.01 sec 26.2 MBytes 221 Mbits/sec 0 144 KBytes
[ 5] 6.01-7.04 sec 27.5 MBytes 223 Mbits/sec 0 144 KBytes
[ 5] 7.04-8.04 sec 26.2 MBytes 221 Mbits/sec 0 146 KBytes
[ 5] 8.04-9.03 sec 26.2 MBytes 221 Mbits/sec 0 146 KBytes
[ 5] 9.03-10.05 sec 25.0 MBytes 205 Mbits/sec 0 168 KBytes
root@apalis-tk1:~# lsusb -t
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/2p, 5000M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=ax88179_178a, 5000M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/6p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-ehci/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
It is the same using latest AX88179 driver or the default one from kernel.
The read speed of USB3.0 USB stick on USBH4 could be up to 110.65MB/sec. So the USBH4 of TK1 should be enough for GbE bandwidth.
root@apalis-tk1:~# hdparm -t /dev/sda
/dev/sda:
Timing buffered disk reads: 332 MB in 3.00 seconds = 110.65 MB/sec
Do you know how to get full speed of USB3.0 GbE on USBH4 of TK1?
Thanks!
