USB Web cam on Verdin Development Board V1.1 and Verdin iMX8M Plus
How to use USB Web camera To read videos and capture images in python application is possible?
In som:-Verdin iMX8M Plus ,Carrier Board :- Verdin Development Board V1.1,OS:- Linux
Greetings @saikumar,
We have general article on using cameras in TorizonCore here: How to use Cameras on Torizon | Toradex Developer Center
It also features an example application with cameras and opencv that could serve as a inspiration.
Thank you for your inputs .
But i an using opencv in visual studio
the docker file :-
ARGUMENTS --------------------------------------------------------------------
Board architecture
ARG IMAGE_ARCH=
For armv7 use:
#ARG IMAGE_ARCH=arm
Base container version
ARG BASE_VERSION=3.0.8-bookworm
ARG APP_ROOT=/home/torizon
FROM --platform=linux/${IMAGE_ARCH}
torizon/debian:${BASE_VERSION} AS Deploy
ARG IMAGE_ARCH
ARG APP_EXECUTABLE
ARG APP_ROOT
your regular RUN statements here
Install required packages
RUN apt-get -q -y update &&
apt-get -q -y install
python3-minimal
python3-pip
python3-venv \
DO NOT REMOVE THIS LABEL: this is used for VS Code automation
# __torizon_packages_prod_start__
python3-opencv:arm64 \
# __torizon_packages_prod_end__
&& apt-get clean && apt-get autoremove && \
rm -rf /var/lib/apt/lists/*
Create virtualenv
RUN python3 -m venv ${APP_ROOT}/.venv --system-site-packages
Install pip packages on venv
COPY requirements-release.txt /requirements-release.txt
RUN . ${APP_ROOT}/.venv/bin/activate &&
pip3 install --upgrade pip && pip3 install --break-system-packages -r requirements-release.txt &&
rm requirements-release.txt
copy the source code
COPY /src ${APP_ROOT}/src
WORKDIR ${APP_ROOT}
ENV APP_ROOT=${APP_ROOT}
Activate and run the code
CMD . ${APP_ROOT}/.venv/bin/activate && python3 src/main.py --no-sandbox
main.py:-
import opencv
Open the webcam (0 represents the default camera)
cap = opencv.VideoCapture(0)
while True:
# Capture frame-by-frame
ret, frame = cap.read()
# Display the frame
opencv.imshow('Webcam', frame)
# Press 'q' to exit
if opencv.waitKey(1) & 0xFF == ord('q'):
    break
Release the capture
cap.release()
opencv.destroyAllWindows()
i am getting error at import opecv
please help me to resolve the issue
Could you elaborate what specific error you get?
Also how did you modify your torizonPackages.json file to add python3-opencv:arm64? If you’re running things in debug then you need to add this package to the debug container. It looks like you added it to only the release container which won’t do you any good if you’re running in debug. This page explains this more in detail: Add Packages, Libraries and Tools | Toradex Developer Center
On a final note, if you’re just trying to use the camera you don’t need to really mess with this opencv stuff to use a camera. OpenCV is for computer vision, if you just want to use a camera then you can just use Gstreamer. There’s many examples you can find online of Gstreamer.
