Verdin has only 1 RGMII already used by Ethernet PHY, but I need another RGMII for a QCA7500 PLC.
Has anyone used a USB to RGMII/RMII converter to expand the number of RGMII/RMII, such as LAN7801 ?
Thank you.
Thank you.
Hello raton,
Well the verdin IMX8M mini has only one RGMII but the Verdin IMX8M plus has a second one.
Please check if the Plus would be an option for you. Our Verdin development board also has already a second Ethernet PHY on board.
For USB to Ethernet, the Microchip Phys are commonly used.
Matthias
that’s a good suggestion, I will take a look at imx8m-plus. Thank you
