I want to get a USB to ethernet adpater to work, but there is no new network interface when its connected…
Linux version is:
root@colibri-imx8x:~# uname -a
Linux colibri-imx8x 5.4.91-5.2.0-devel+git.590db576d04d #1 SMP PREEMPT Tue Feb 2 16:38:41 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
Usb device is detected:
Bus 003 Device 007: ID 0b95:772b ASIX Electronics Corp. AX88772B
But there is no new interface:
root@colibri-imx8x:~# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:14:2D:67:B8:01
inet addr:10.10.10.109 Bcast:10.10.10.255 Mask:255.255.255.0
inet6 addr: fe80::214:2dff:fe67:b801/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1380 errors:0 dropped:0 overruns:0 frame:0
TX packets:850 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1796736 (1.7 MiB) TX bytes:82584 (80.6 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:856 errors:0 dropped:0 overruns:0 frame:0
TX packets:856 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:56494 (55.1 KiB) TX bytes:56494 (55.1 KiB)
usb-net module seems to be present as I got the following, but I´m not sure if its loaded correctly, as modprobe does not give an output:
root@colibri-imx8x:~# ls /lib/modules/5.4.91-5.2.0-devel+git.590db576d04d/kernel/drivers/net/usb/
cdc_ether.ko rndis_host.ko usbnet.ko
root@colibri-imx8x:~# modprobe usbnet
but rmmod succeeds just ones so probably it is loaded:
root@colibri-imx8x:~# rmmod usbnet
rmmod: ERROR: Module usbnet is not currently loaded
Is there another step necessary that I´m missing in order to get the adapter working?
