I’m currently experience the same issue like in USB storage not found in U-Boot when using USB Hub - Apalis iMX8 with the Ixora 1.3A Carrier Board and an Apalis iMX8 QuadPlus 2GB.
If I put the apalis into an ixora 1.2A the usb storage device is detected in u-boot.
The workaround with setting GPI 132 works for me too.
I’m on the Toradex Reference Image TDX Wayland with XWayland 6.3.0-devel-20230626+build.320 (kirkstone) apalis-imx8-07314409 ttyLP1
Apalis-iMX8_Reference-Minimal-Image with u-boot U-Boot 2022.04-6.3.0-devel+git.c71ae7141f30 (May 15 2023 - 16:20:01 +0000)
So we maybe need an change in the device tree in u-boot?
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 37C
DRAM: 2 GiB
Core: 193 devices, 19 uclasses, devicetree: separate
In: serial
Out: serial
Err: serial
Model: Toradex 0049 Apalis iMX8QP 2GB V1.1C
Serial#: 07314409
BuildInfo:
- SCFW f5623878, SECO-FW c9de51c0, IMX-MKIMAGE 3bfcfccb, ATF 3c1583b
- U-Boot 2022.04-6.3.0-devel+git.c71ae7141f30
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
Apalis iMX8 # usb start
starting USB...
Bus usb@5b0d0000: Port not available.
Bus usbh3: XHCI-imx8 init hccr 0x000000005b130000 and hcor 0x000000005b130080 hc_length 128
Register 2000820 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usbh3 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Apalis iMX8 # usb tree
USB device tree:
1 Hub (5 Gb/s, 0mA)
U-Boot XHCI Host Controller
Apalis iMX8 # gpio set 132
gpio: pin 132 (gpio 132) value is 1
Apalis iMX8 # usb reset
resetting USB...
USB XHCI 1.00
scanning bus usbh3 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
USB device tree:
1 Hub (5 Gb/s, 0mA)
+-2 Mass Storage (480 Mb/s, 100mA)
ATP Electronics NANODURA 9900422021600626
Hi @jonas-licht,
Thanks for reporting.
Do you see the same behaviour if you use the Toradex Reference Image 6.2 instead of 6.3 ?
Kevin
Hello @jonas-licht ,
Do you have any updates on this topic?
Josep
sorry for the delay, I was on vacation.
I see the same behavior with the 6.2 reference image:
U-Boot 2022.04-6.2.0+git.0e1f11392251 (Mar 07 2023 - 15:27:59 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 33C
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Serial#: 07314409
BuildInfo:
- U-Boot 2022.04-6.2.0+git.0e1f11392251
Fastboot: Normal
Normal Boot
starting USB...
USB XHCI 1.00
USB device tree:
1 Hub (5 Gb/s, 0mA)
resetting USB...
USB XHCI 1.00
USB device tree:
1 Hub (5 Gb/s, 0mA)
Apalis iMX8 #
Regards, Jonas
I have been able to reproduce your issue and have asked internally. about it.
We will post any updates on this thread.
Josep
This issue will be fixed in version 6.5.0 (and also in 5.7.4 for those using BSP 5)
Josep
@josep.tx I see a tag for release 5.7.4, but I do not see that release on Embedded Computing News (toradex.com). There the last release is 5.7.2.
Also on Release Matrix - Kernel/U-Boot Version | Toradex Developer Center the latest release in the BSP5 series is 5.7.2.
Could you give some insights in the fitness of release 5.7.4 for use in production?
Hello @hvdbrand ,
5.7.4 has just been released. You can find it here:
Download Links | Toradex Developer Center
Regarding your question :
Maintenance releases are production releases. We run a set of tests to validate them.
Learn more about our release types from our Embedded Linux Support Strategy.
Josep
