I am using a Colibri iMX7 and I have a problem with the USB serial on X27.
The only way to have it worked is to enter Recovery Mode doing ./update.sh -d and then I have the serial output.
But if I do a hard Reset, a software reboot, or a power off/on I have nothing on the serial output..
During the boot after the recovery mode I can see this error :
[FAILED] Failed to start Load default USB gadget schema g1.schema.
See 'systemctl status usbg.service' for details.
And systemctl status usbg.service returns :
[0;1;31m●[[0m usbg.service - Load default USB gadget schema g1.schema
Loaded: loaded (/lib/systemd/system/usbg.service; enabled; vendor preset: enabled)
Active: [[0;1;31mfailed[[0m (Result: exit-code) since Fri 2017-03-31 10:04:08 UTC; 22s ago
Process: 305 ExecStartPost=/bin/sh -c /bin/cat /proc/device-tree/serial-number > /sys/kernel/config/usb_gadget/g1/strings/0x409/s
erialnumber [[0;1;31m(code=exited, status=1/FAILURE)[[0m
Process: 301 ExecStartPost=/bin/sh -c /bin/cat /proc/device-tree/model > /sys/kernel/config/usb_gadget/g1/strings/0x409/product (
code=exited, status=0/SUCCESS)
Process: 289 ExecStart=/usr/bin/gadget-import g1 /etc/usbg/g1.schema (code=exited, status=0/SUCCESS)
Main PID: 289 (code=exited, status=0/SUCCESS)
Mar 31 10:04:08 colibri-imx7 systemd[1]: Starting Load default USB gadget schema g1.schema...
Mar 31 10:04:08 colibri-imx7 sh[305]: cat: can't open '/proc/device-tree/serial-number': No such file or directory
Mar 31 10:04:08 colibri-imx7 systemd[1]: [[0;1;39musbg.service: Control process exited, code=exited status=1[[0m
Mar 31 10:04:08 colibri-imx7 systemd[1]: [[0;1;31mFailed to start Load default USB gadget schema g1.schema.[[0m
Mar 31 10:04:08 colibri-imx7 systemd[1]: [[0;1;39musbg.service: Unit entered failed state.[[0m
Mar 31 10:04:08 colibri-imx7 systemd[1]: [[0;1;39musbg.service: Failed with result 'exit-code'.[[0m
I have this problem since I flashed my board.
Any idea?
Thank you for help !
I assume you mean the USB to Serial Connector X27 on our Colibri Evaluation Board, right? I further assume you did set the jumpers JP17, JP19, JP20, JP21 to position 2-3 for the Colibri UART_A to be connected to the USB to serial chip/connector?
That sounds rather strange. And you are sure you are not talking about USB Client X29 shared with USB OTG X30?
See ‘systemctl status usbg.service’ for details. have this problem since I flashed my board.
That really has nothing to do with UART_A potentially routed to X27 as the Colibri module knows nothing about this potentially being converted to USB. However that talks about the USB client side of things which would require separate activation as explained in the following article on our developer website. Note that this similarly applies to the Colibri iMX7 as well.
May I ask what exact model (e.g. Solo vs. Dual) and version (e.g. V1.1A, V1.1B or V1.1C) we are talking about?
And what BSP version are you trying this with?
It is possible that you’ve accidentally erased bcb data from flash, when in recovery try this commands:
Colibri iMX7 # nand erase.chip
Colibri iMX7 # run setupdate
Colibri iMX7 # run create_bcb
Colibri iMX7 # run update
Colibri iMX7 Dual V1.1C and I flashed the latest BSP downloaded here : High performance, low power | Footprint for embedded computing
Is it normal while I am in Recovery mode (since there is a known issue about flashing through USB) to configure a flashing process over Ethernet or SD card ?
Yes ! You saved my day ! I surely accidentally erased bcb data from flash. Thank you
FWIW, we use the serial number in the USB descriptor field. The serial number gets loaded from the device tree ( /proc/device-tree/serial-number). In your case that file was missing, hence initializing the USB gadget failed.
