I’m trying to toggle USB port power by toggling the enable inputs to the USB power switches (SODIMM_155, SODIMM_185) but have been unsuccessful using /sys/bus/usb in torizon 6.5.0. Solutions such as Linux control USB power-enable switch do not appear to apply to current BSPs. I have confirmed that the devicetrees are correct for the USB enable outputs and if I unbind the regulators the output will go low and turn off the port:
line 12: “SODIMM_155” “regulator-usb1-vbus” output active-high [used]
line 13: “SODIMM_157” unused input active-high
line 14: “SODIMM_185” “regulator-usb2-vbus” output active-high [used]
echo “regulator-usb1-vbus” | sudo tee /sys/bus/platform/drivers/reg-fixed-voltage/unbind
echo “regulator-usb2-vbus” | sudo tee /sys/bus/platform/drivers/reg-fixed-voltage/unbind
I’ve tried unbinding the driver and using autosuspend but have been unsuccessful:
echo “usb1” | sudo tee /sys/bus/usb/drivers/usb/unbind
echo “usb2” | sudo tee /sys/bus/usb/drivers/usb/unbind
echo “0” | sudo tee /sys/bus/usb/devices/1-0:1.0/usb1-port1/power/autosuspend_delay_ms
echo “auto” | sudo tee /sys/bus/usb/devices/1-0:1.0/usb1-port1/power/control
echo “0” | sudo tee /sys/bus/usb/devices/2-0:1.0/usb2-port1/power/autosuspend_delay_ms
echo “auto” | sudo tee /sys/bus/usb/devices/2-0:1.0/usb2-port1/power/control
It also appears that I can’t use uhubctl on the root hubs per USB Host Mode (Linux):
torizon@verdin-imx8mp-15242127:~/debug-scripts$ sudo uhubctl
No compatible devices detected!
torizon@verdin-imx8mp-15242127:~/debug-scripts$ sudo uhubctl -f
Current status for hub 4 [1d6b:0003 Linux 5.15.129-6.5.0-devel+git.d6880bf83a40 xhci-hcd xHCI Host Controller xhci-hcd.2.auto, USB 3.00, 1 ports, nops]
Port 1: 02a0 power 5gbps Rx.Detect
Current status for hub 3 [1d6b:0002 Linux 5.15.129-6.5.0-devel+git.d6880bf83a40 xhci-hcd xHCI Host Controller xhci-hcd.2.auto, USB 2.00, 1 ports, nops]
Port 1: 0100 power
Current status for hub 2 [1d6b:0003 Linux 5.15.129-6.5.0-devel+git.d6880bf83a40 xhci-hcd xHCI Host Controller xhci-hcd.1.auto, USB 3.00, 1 ports, nops]
Current status for hub 1 [1d6b:0002 Linux 5.15.129-6.5.0-devel+git.d6880bf83a40 xhci-hcd xHCI Host Controller xhci-hcd.1.auto, USB 2.00, 1 ports, nops]
Port 1: 0100 power
Can USB port power still be toggled using /sys/bus/usb?
I’d be glad to help! Could you let me know which hardware you’re using and which version of Torizon OS you’re running? For example, are you using a Verdin iMX8M Plus, Verdin AM62, or another SoM? And what’s the exact version of Torizon OS 6.5.0 (e.g., 6.5.0-build.XX)?
The USB power control approach varies significantly between different hardware platforms and OS versions, so I want to ensure I provide you with the correct guidance for your specific setup.
I don’t have specific documentation about USB port power control via /sys/bus/usb for your exact setup (Verdin iMX8M Plus on Mallow Board with Torizon OS 6.5.0-devel) in the available sources.
However, your approach of unbinding the regulators appears to be working correctly, as you’ve confirmed that unbinding the fixed voltage regulators does turn off the USB ports:
echo "regulator-usb1-vbus" | sudo tee /sys/bus/platform/drivers/reg-fixed-voltage/unbind
echo "regulator-usb2-vbus" | sudo tee /sys/bus/platform/drivers/reg-fixed-voltage/unbind
For more comprehensive information about USB power control methods and troubleshooting, I’d recommend checking these potentially relevant sources:
USB port power cannot be toggled using the standard /sys/bus/usb interfaces (autosuspend, power/control, driver unbind, etc.) on the Verdin iMX8M Plus with Torizon 6.8.0
The VBUS power switches on SODIMM_155 (USB1) and SODIMM_185 (USB2) are not controlled by the xHCI host controller or the USB subsystem.
They are managed exclusively by the fixed-voltage regulators (regulator-usb1-vbus / regulator-usb2-vbus) in the device tree, which directly drive the GPIO enable signals (active-high).
Unbinding the regulator driver is the only reliable way in the current BSP to drive the enable pins low and cut VBUS:
