I have USB host connector connected to OTG port of Colibri IMX6
With my settings USB works but all services get crazy. If I open command prompt and give command “services list” then all services (eg. TELNET and FTP) are in state “unknown” and they do not work.
If I remove HCD_HSH2 key from my OsDesign.reg file OR change Order attribute to higher e.g 0x30 then USB does not work but all services work.
I am using BSP 1.2b4
Below are my registry settings for USB
; Default configuration loads the OTG driver that then acrivates the host or function drivers when needed
; This can be overridden to force the USB port in host or device-only mode
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\UsbOtg]
; Dll" = “fsl_usbotg.dll”
Dll" = “_fsl_usbotg.dll”
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\UsbOtg\USBFN]
;“Dll”=“usbfn.dll”
“Dll”=“_usbfn.dll”
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\UsbOtg\Hcd]
;“Dll”=“hcd_hsotg.dll”
“Dll”=“_hcd_hsotg.dll”
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\HCD_HSH2]
“Prefix”=“HCD”
“Order”=dword:15
“Class”=dword:0c
“SubClass”=dword:03
“ProgIF”=dword:20
“InterfaceType”=dword:0
“MemBase”=dword:2184000
“MemLen”=dword:1000
“irq”=dword:4B
“IsrDll”=“giisr.dll”
“IsrHandler”=“ISRHandler”
“OTGSupport”=dword:0
“OTGGroup”=“02”
;“HighSpeed”=dword:0 ; by default its 1, you can set 0 to force FullSpeed
