Tips on what to check to troubleshoot USB devices are not being detected?
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
- The keyboard works fine on other embedded Linux devices.
- The keyboard had worked previously ( yet not the same image version ).
dmesg output:
dmesg |grep -i USB [ 0.085674] usb_host_vbus: supplied by usb_host_vbus_hub [ 0.087026] usbcore: registered new interface driver usbfs [ 0.087071] usbcore: registered new interface driver hub [ 0.087149] usbcore: registered new device driver usb [ 0.523526] usbcore: registered new interface driver asix [ 0.523576] usbcore: registered new interface driver ax88179_178a [ 0.523609] usbcore: registered new interface driver cdc_ether [ 0.523644] usbcore: registered new interface driver net1080 [ 0.523679] usbcore: registered new interface driver cdc_subset [ 0.523714] usbcore: registered new interface driver zaurus [ 0.523773] usbcore: registered new interface driver cdc_ncm [ 0.523779] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.523974] usbcore: registered new interface driver usb-storage [ 0.524053] usbcore: registered new interface driver usbserial [ 0.524086] usbcore: registered new interface driver usbserial_generic [ 0.524120] usbserial: USB Serial support registered for generic [ 0.524151] usbcore: registered new interface driver ftdi_sio [ 0.524177] usbserial: USB Serial support registered for FTDI USB Serial Device [ 0.524205] usbcore: registered new interface driver pl2303 [ 0.524231] usbserial: USB Serial support registered for pl2303 [ 0.525382] usbmisc_imx 2184800.usbmisc: 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator [ 0.526478] imx_usb 2184000.usb: 2184000.usb supply vbus not found, using dummy regulator [ 0.531706] imx_usb 2184200.usb: 2184200.usb supply vbus not found, using dummy regulator [ 0.534953] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1 [ 0.562762] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00 [ 0.563455] hub 1-0:1.0: USB hub found [ 0.928151] usbcore: registered new interface driver usbhid [ 0.928155] usbhid: USB HID core driver [ 7.706837] usb0: HOST MAC be:43:b9:5c:15:18 [ 7.709773] usb0: MAC 0a:43:7d:c2:9b:6d [ 7.781194] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready [ 31.192855] usb_otg_vbus: disabling [ 31.192868] usb_host_vbus_hub: disabling [ 31.192879] usb_host_vbus: disabling
Thanks in advance for any tips or suggestions,
-Ed
