USB HID Touch for LILLIPUT display FA1012
As announced in this article USB HID are support by Toradex ARM Computer Modules.
But the Generic USB HID Driver is only available for WinCE.
Is there a Generic USB HID Driver for Linux too on iMX6 ?
Hi
In Linux that is a job for the kernel and can be selected by the kernel configuration.
For all our kernels the relevant driver is configured. IIRC as a kernel module.
Once the USB subsystem enumerates a USB HID device the driver will be loaded and should provide your touch as a new input device.
You could start the command line tool ‘evtest’ to get a list of the currently recognized input devices. Choose one from the list to log the events generated by it to the console:
root@colibri-imx6:~# evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:      stmpe-ts
/dev/input/event1:      gpio-keys.29
/dev/input/event2:      USB Mouse
Select the device event number [0-2]: 0
Input driver version is 1.0.1
Input device ID: bus 0x18 vendor 0x0 product 0x0 version 0x0
Input device name: "stmpe-ts"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 330 (BTN_TOUCH)
  Event type 3 (EV_ABS)
    Event code 0 (ABS_X)
      Value      0
      Min        0
      Max     4095
    Event code 1 (ABS_Y)
      Value      0
      Min        0
      Max     4095
    Event code 24 (ABS_PRESSURE)
      Value      0
      Min        0
      Max      255
Properties:
Testing ... (interrupt to exit)
Event: time 1481636247.292062, type 3 (EV_ABS), code 0 (ABS_X), value 2453
Event: time 1481636247.292062, type 3 (EV_ABS), code 1 (ABS_Y), value 1929
Event: time 1481636247.292062, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 44
Event: time 1481636247.292062, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Max
