We check assign pin for Colibri iMx6(DL) on u-boot-toradex/linux-toradex(device-tree) source code.
On each source code, checked that those pins is defined as GPIO, not defined USB.
Is it not necessary to define USB ?
pin
SODIMM Pin129 USB_H_PWR_EN
SODIMM Pin131 USB_H_OC
u-boot
u-boot-toradex/board/toradex/colibri_imx6/colibri_imx6.c
iomux_v3_cfg_t const gpio_pads[] = {
MX6_PAD_EIM_D30__GPIO3_IO30 | MUX_PAD_CTRL(WEAK_PULLUP), // -> MX6QDL_PAD_EIM_D31__USB_H1_PWR ?
/* USBC_ID */
MX6_PAD_NANDF_D2__GPIO2_IO02 | MUX_PAD_CTRL(WEAK_PULLUP),
/* USBC_DET */
MX6_PAD_GPIO_17__GPIO7_IO12 | MUX_PAD_CTRL(WEAK_PULLUP),
iomux_v3_cfg_t const usb_pads[] = {
/* TODO This pin has a dedicated USB power functionality, can we use it? */
/* USB_PE */
MX6_PAD_EIM_D31__GPIO3_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL), // -> MX6QDL_PAD_EIM_D30__USB_H1_OC ?
# define GPIO_USB_H_EN IMX_GPIO_NR(3, 31)
- linux device tree
like u-boot source code.
