TJO
June 15, 2020, 8:23am
1
Hi Toradex
I try to load the latest Easy Installer 2.0b5 onto a iMX6S module.
I enter the bootloader on the module and activate the USB boot mode.
I than connect the USB Client (OTG) on the Evaluation board to my PC.
But it cant find the USB device. I have a “Unknown Device (Device Descriptor Request Failed)”
I have tried on two PC’s. Same result,
I there a missing driver?
Thomas
Could you please specify which carrier board do you have and OS type and version you run on your desktop?
TJO
June 16, 2020, 6:39am
3
Hi
Im using Colibri Evalution Board, the latest version.
I’m running Windows 10, build 17763
Thomas
Hi
Thanks for this Information. Could you run the recovery-windows.bat
and share the output in text format.
Thanks and best regards,
TJO
June 16, 2020, 10:39am
6
Here are the logs from recovery-windows.bat and the bootloader when starting “bmode usb”
Adding files semas not to work
Bootloader:
Commercial temperature grade DDR3 timings, 32bit bus width.
Trying to boot from MMC1
U-Boot 2016.11-1.1.0+g51b53b4 (Sep 06 2017 - 15:18:21 -0700)
CPU: Freescale i.MX6SOLO rev1.1 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 256 MiB
PMIC: device id: 0x10, revision id: 0x21, programmed
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Using default environment
In: serial_mxc
Out: serial_mxc
Err: serial_mxc
Model: Toradex Colibri iMX6 Solo 256MB V1.1A, Serial# 05127328
Net: using PHY at 0
FEC [PRIME]
Colibri iMX6 #
**Recovery bat:**
Downloading Toradex Easy Installer...
config file
vid=0x15a2 pid=0x0054 file_name=mx6_usb_rom.conf
-> vid=0x1b67 pid=0x4fff file_name=mx6_usb_sdp_spl.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0061 file_name=mx6_usb_rom.conf
vid=0x15a2 pid=0x0076 file_name=mx7_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx7_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0080 file_name=mx6ull_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6ull_usb_sdp_uboot.conf
config file
parse recovery\\\mx6_usb_rom.conf
Trying to open device vid=0x15a2 pid=0x0061
Interface 0 claimed
HAB security state: development mode (0x56787856)
== work item
filename SPL
load_size 0 bytes
load_addr 0x13f00000
dcd 0
clear_dcd 0
plug 0
jump_mode 2
jump_addr 0x00000000
== end work item
loading binary file(SPL) to 00907400, skip=0, fsize=bc00 type=aa
<<<48128, 48128 bytes>>>
succeeded (status 0x88888888)
jumping to 0x00907400
config file
parse recovery\\\mx6_usb_sdp_spl.conf
Trying to open device vid=0x1b67 pid=0x4fff
Interface 0 claimed
== work item
filename u-boot.img
load_size 0 bytes
load_addr 0x03f00001
dcd 0
clear_dcd 0
plug 0
jump_mode 2
== end work item
loading binary file(u-boot.img) to 177fffc0, skip=0, fsize=4ce68 type=aa
<<<314984, 315392 bytes>>>
jumping to 0x177fffc0
config file
parse recovery\\\mx6_usb_sdp_uboot.conf
Trying to open device vid=0x1b67 pid=0x4000.........................
Could not open device vid=0x1b67 pid=0x4000
ECHO is off.
Downloading Toradex Easy Installer failed...
Press any key to continue . . .
Perfect that it works. Thanks for you feedback.
Hi @TJO
Just to be sure. Did you really use the Colibri version of Toradex Easy Installer?
Could you also share the output from the console of the SoM?
