I installed Torizon OS 6.8.1+build.25 on my Verdin iMX8M-Plus mounted on Yavia.
It comes with u-boot 2022.04
-Boot SPL 2022.04-6.8.1+git.a31fdd543bee (Jan 01 1970 - 00:00:00 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
Training FAILED
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
DDR configured as single rank
SEC0: RNG instantiated
Normal Boot
WDT: Started watchdog@30280000 with servicing (60s timeout)
Trying to boot from BOOTROM
Boot Stage: Primary boot
Find img info 0x&4802a600, size 888
Need continue download 1024
Download 951296, Total size 952656
NOTICE: BL31: v2.6(release):lf_v2.6-g3c1583ba0a
NOTICE: BL31: Built : 00:00:00, Jan 1 1970
I stop the bloot in u-boot and then I plug an USB stick into J8 port (USB 2.0).
All the USB sticks I use are formatted in FAT32.
Then I run usb start command in u-boot.
Some of them work properly and I see the following log:
Verdin iMX8MP # usb start
starting USB...
Bus usb@38100000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@38200000: Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus usb@38100000 for devices... 1 USB Device(s) found
scanning bus usb@38200000 for devices... 3 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Some of them don’t work with the following log:
starting USB...
USB XHCI 1.10
USB XHCI 1.10
scanning bus usb@38200000 for devices... WARN halted endpoint, queueing URB anyway.
Unexpected XHCI event TRB, skipping... (ffb448f0 00000000 13000000 02008400)
BUG at drivers/usb/host/xhci-ring.c:530/abort_td()!
BUG!
resetting ...
Then the device reboots with the following log:
U-Boot SPL 2022.04-6.8.1+git.a31fdd543bee (Jan 01 1970 - 00:00:00 +0000)
Training FAILED
Normal Boot
U-Boot 2022.04-6.8.1+git.a31fdd543bee (Jan 01 1970 - 00:00:00 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 26C
Reset cause: POR
DRAM: 4 GiB
Core: 89 devices, 23 uclasses, devicetree: separate
MMC: FSL_SDHC: 1, FSL_SDHC: 2
In: serial
Out: serial
Err: serial
Model: Toradex 0058 Verdin iMX8M Plus Quad 4GB WB IT V1.1A
Serial#: 15007389
Carrier: Toradex Yavia V1.0A, Serial# 35408100
BuildInfo:
- ATF 3c1583b
flash target is MMC:2
Net: eth1: ethernet@30be0000, eth0: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Normal Boot
starting USB...
USB XHCI 1.10
USB XHCI 1.10
scanning bus usb@38200000 for devices... Device not responding to set address.
USB device not accepting new address (error=80000000)
2 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Is there something wrong in the USB handling of u-boot?
