USB Common Mode Choke
G’day,
I’m laying out my custom carrier board at the moment, and am a little confused regarding the USB3.0 common mode chokes used in the Ixora carrier board. The choke used is the DLW21SN900SQ2L, which has the following equivalent circuit:
[upload|80+gGG+E1gRqSYW35MNMBCtw/eY=]
My interpretation of this image, is that pads 1 and 2 are connected, and pads 3 and 4 are connected. However, the schematic for the Ixora shows connections between pads 2 and 3, and between 1 and 4:
[upload|EBjR/F+yEcj4Ys0Q23vS1kyeZsg=]
These connections are obviously reiterated in the Ixora layout:
[upload|VQSm9HC2phmztmEbd99iDpzNJ7g=]
The Ixora carrier board obviously works as intended, so I’m guessing I’ve just misunderstood the equivalent circuit?
Dear @jars121,
thank you very much for using the Toradex developer community.
You are definitely right, the way this component has been added to the Altium library might be a bit confusing.
Nevertheless, it works because the pins are assigned in the same way in both the schematic and pcb library.
It is basically a different numbering approach but the equivalent circuit and the pcb footprint are perfectly fine.
I hope that I managed to clarify your doubts, please get back to me if you need further details.
Thanks for confirming @diego.tx, that all makes sense; I thought I was going crazy!
Dear @jars121,
not at all! thanks again for your comment, please don’t hesitate to use again the community if you need!
