Also, what version of TightVNC to you use?
alex.tx
December 4, 2025, 7:53pm
22
I haven’t performed any configuration. When the Verdin iMX95 is running the Toradex Easy Installer, Windows should recognize it as a USB-NCM network device. You can ping it at IP address 192.168.11.1 and use a VNC client to access the Toradex Easy Installer GUI using the same IP address.
Do i have to use 192.168.11.1? I have a conflict with this IP address. I have configured it to 192.168.11.21.
alex.tx
December 4, 2025, 8:13pm
24
It’s OK — that’s the Windows machine’s IP. But the Mallow board’s IP is 192.168.11.1
Ok, making progress. I get this screen now:
Why don’t I see any packages?
alex.tx
December 4, 2025, 8:43pm
26
Have you connected the Mallow board to the network?
It is connected with ethernet:
And I see activity on the ethernet LEDs
I changed my cable and the problem is resolved:
I flashed the Toradex Embedded Linux Reference Multimedia Image. Now I can ssh into the board! Thanks for your help.
But if I want to re-flash, how do I do that? Now the Toradex Easy Installer is no longer flashed, so I can’t use TightVNC to connect and reflash.
alex.tx
December 4, 2025, 10:06pm
31
Put module into recovery mode . Then load the Toradex Easy Installer over USB , When the Toradex Easy Installer boots, it configures the port as RNDIS so you can access the Easy Installer GUI using VNC.
