USB 3.0 Support on Apalis TK1 with Ubuntu 14.04. LTS
Hi
I got a Apalis TK1 with Ixora V1.0A now running Ubuntu 14.04. LTS.
I’m using a USB 3.0 Camera from E-Con, but the transmission rate is not as good as it should be.
After a bit of research, I found this article from E-Con: See3CAMs on Jetson TK1 (ARM) over USB 3.0
Is it necessary to enale usb 3.0 support and Hidraw support with Apalis TK1 too?
Thanks for any help.
I got a Apalis TK1 with Ixora V1.0A now running Ubuntu 14.04. LTS. I’m using a USB 3.0 Camera from E-Con, but the transmission rate is not as good as it should be.
We once tested Apalis TK1 with a Basler USB 3.0 Vision camera reaching 1920 x 1200 at 120 fps without any issues.
After a bit of research, I found this article from E-Con: https://www.e-consystems.com/Articles/Camera/USB-3-Camera-on-JetsonTK1-kit.asp
No, both should already be enabled for you by default.
You are very welcome.
