USB 3.0 on Apalis Evaluation Board V1.1A
Is it possible to use USB 3.0: X51 USB HOST SS port from Apalis Evaluation Board V1.1A under apalis T30? When I plug the device, power to the device is applied, but I cannot see any new device under the system. I would like to mention, that I`m using standard USB 2.0 cable for the connection. Thanks in advance for your reply.
No, the X51 USB host port is not available when using Apalis T30. It would be available as USB 2.0 on Apalis iMX6 and as true USB 3.0 on the upcoming Apalis TK1.
