I’m using a VF50 module with Linux V2.5. I need to update the version of OpenSSL. The current version reads: “OpenSSH_7.4p1, OpenSSL 1.0.2d 9 Jul 2015”. I have managed to update OpenSSH, but OpenSSL is proving more problematic.
I have copied the OpenSSL 1.0.2k recipe from the link below to my recipe:
However, compilation fails with the following error:
MACHINE=colibri-vf bitbake openssl
Loading cache: 100% |###########################################################################################################################################################| ETA: 00:00:00
Loaded 2828 entries from dependency cache.
ERROR: ParseError at /opt/TORADEX_COLIBRI_VF_V2.5/build/../stuff/meta-timetools/recipes-timetools/openssl/openssl.inc:31: Could not inherit file classes/relative_symlinks.bbclassETA: --:--:--
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
You can probably just cherry-pick them. However, depending on what you are actually trying to achieve it may be easier to update to out latest morty based bsp and used upstream openembedded-core in the build.
