Updating from BSP5 to BSP6 uImage vs. zImage
Hello
I am in the process of upgrading the BSP for my embedded devices. Currently I am able to compile complete images with Yocto BSP 5. My devices in the field use BSP 2.8. Since BSP 5 is now also outdated, I am trying to use BSP 6 directly.
One of my last problems is the format of the Linux kernel. So far, my devices have always used uImage. I was also able to continue this in BSP 5 using KERNEL_IMAGETYPE_forcevariable = ‘uImage’. With BSP 6, however, I get compile errors from linux-toradex-mainline when I enter KERNEL_IMAGETYP:forcevariable = ‘uImage’ in the local.conf.
A complex update mechanism is used in the field. This ensures that the last executable image can be switched to in the event of an error. The use of a different kernel format requires adjustments in the U-Boot during the update, so for me it seems easiest to stay with the uImage format and not switch to the current standard zImage.
Please help me with this problem. How can I compile a uImage with BSP 6? Alternatively, can I patch the U-Boot so that an old uImage is used as a fallback instead of zImage? The following cases are to be covered:
  • New devices
  • Upgrade of existing devices
  • Failed updates
  • Downgrade of old and new devices.
Thank you for your support.
We use apalix imx6 in all hardware variants on different self-developed boards.
Thank you for reaching out with your question about upgrading to BSP 6 while maintaining the uImage format for your Apalis iMX6 devices. Let’s explore how you can achieve this.
Compiling uImage with BSP 6
  1. Yocto Configuration Adjustments:
    • BSP 6 defaults to zImage, but you can attempt to compile a uImage by setting the KERNEL_IMAGETYPE in your Yocto configuration. Add the following line to your local.conf:
      KERNEL_IMAGETYPE = "uImage"
    • If you encounter errors, it may indicate that BSP 6 does not natively support uImage due to changes in the kernel build process.
  2. Using the mkimage Tool:
    • If direct support is unavailable, you can convert a zImage to uImage using the mkimage tool from U-Boot tools. First, compile the kernel as zImage, then use the following command:
      mkimage -A arm -O linux -T kernel -C none -a 0x80008000 -e 0x80008000 -n "Linux Kernel" -d zImage uImage
Modifying U-Boot for Fallback
  1. U-Boot Configuration:
    • Modify U-Boot to support both zImage and uImage. Update the boot script to check for both image types and load the appropriate one.
  2. Testing Across Scenarios:
    • Ensure thorough testing of your modified U-Boot and kernel images for all scenarios: new devices, upgrades, failed updates, and downgrades.
By following these steps, you can maintain compatibility with your existing update mechanism while transitioning to BSP 6. If manual conversion or U-Boot modifications are not feasible, consider the benefits of transitioning fully to zImage for future-proofing your deployment.
I hope this helps you with your upgrade process.
Toradex AI Assistant
Does HAB fall back to a correctly signed boot partition, if current boot partition is wrongly signed?.
That’s exactly what I was trying to do. There is a compilation error.
Hi @aweger!
I could convert zImage into uImage using BSP 7 and boot it. Please follow the next steps and check if it solves the problem.
  1. Add the line KERNEL_BOOTCMD = "bootm" at the bottom of your local.conf file.
  2. Build the image.
  3. Find the tarball for the image you built and extract its content. You should have something like this:
├── image.json
├── LA_OPT_NXP_SW.html
├── marketing.tar
├── prepare.sh
├── Reference-Minimal-Image-upstream-apalis-imx6.rootfs.bootfs.tar.xz
├── Reference-Minimal-Image-upstream-apalis-imx6.rootfs.tar.xz
├── SPL
├── u-boot.img
├── u-boot-initial-env-spl
└── wrapup.sh
  1. Extract the rootfs.bootfs.tar.xz file. You’ll find these files:
├── boot.scr
├── imx6q-apalis-eval.dtb
├── imx6q-apalis-eval-v1.2.dtb
├── imx6q-apalis-ixora.dtb
├── imx6q-apalis-ixora-v1.1.dtb
├── imx6q-apalis-ixora-v1.2.dtb
├── overlays
│   ├── apalis-imx6_adv7280_overlay.dtbo
│   ├── apalis-imx6_hdmi_overlay.dtbo
│   ├── apalis-imx6_nau8822-btl_overlay.dtbo
│   ├── apalis-imx6_ov5640_overlay.dtbo
│   ├── apalis-imx6_ov5640-v11a_overlay.dtbo
│   ├── apalis-imx6_panel-cap-touch-10inch_overlay.dtbo
│   ├── apalis-imx6_panel-cap-touch-7inch_overlay.dtbo
│   ├── apalis-imx6_panel-edt-5.7inch_overlay.dtbo
│   ├── apalis-imx6_panel-edt-7inch_overlay.dtbo
│   ├── apalis-imx6_panel-res-touch-7inch_overlay.dtbo
│   ├── apalis-imx6_spi1_spidev_overlay.dtbo
│   ├── apalis-imx6_spi2_spidev_overlay.dtbo
│   ├── apalis-imx6_tc358743_overlay.dtbo
│   └── apalis-imx6_vga-640x480_overlay.dtbo
├── overlays.txt
└── zImage
  1. Install u-boot-tools package by running sudo apt-get install u-boot-tools
  2. Use the following command to convert zImage into uImage (you can find what each variable means in its man page):
mkimage -A arm -O linux -T kernel -C none -a 0x14200000 -e 0x14200000 -n "Linux Kernel" -d zImage uImage
  1. Compress all these files again and use the same name the compressed folder had before. Please be sure to select all the files and then compress them, instead of moving all these files to a folder and then compressing the folder. If you compress a folder, it will not boot.
  2. Add the following line to the u-boot-initial-env-spl file:
kernel_image=uImage
After all these steps, flash the SoM with the built image (you can use a pendrive, for example). I didn’t test it for BSP 6, but it should work too.
This is what I have done, and it worked, but feel free to ask if you face any issues or doubts.
Best regards.
Lucas Azeituno.
Here is my solution, maybe someone else needs it too:
To be able to work with uImage in BSP6, I had to specify the type in two places.
local.conf
KERNEL_IMAGETYPES = "uImage"
Up to BSP5 it was
recipes-kernel/linux/linux-toradex-mainline_%.bbappend
KERNEL_EXTRA_ARGS += "LOADADDR=${UBOOT_ENTRYPOINT}"
Best regard,
Andreas
