I’m updating our cross compilation of Ceres 1.11.0 from 2.7 to 2.8. Here’s the process we are using:
Set Path
PATH=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin:/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi:$PATH
Download Ceres####
mkdir ceres
cd ceres
wget http://ceres-solver.org/ceres-solver-1.11.0.tar.gz
tar xf ceres-solver-1.11.0.tar.gz
Disable some Ceres options
Open the file ceres-solver-1.11.0/CMakeLists.txt
vi ceres-solver-1.11.0/CMakeLists.txt
Change the following options to OFF
- option(GFLAGS "Enable Google Flags."OFF)
- option(SUITESPARSE “Enable SuiteSparse.” OFF)
- option(CXSPARSE “Enable CXSparse.” OFF)
- option(LAPACK “Enable use of LAPACK.” OFF)
- option(OPENMP “Enable threaded solving in Ceres (requires OpenMP)” OFF)
I updated our toolchain.cmake file to reflect the new SDK locations in 2.8.
toolchain.cmake
Now, build using cmake and the new toolchain file:
mkdir build
cd build
cmake -DCMAKE_TOOLCHAIN_FILE=../toolchain.cmake -DCMAKE_INSTALL_PREFIX=/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr ../ceres-solver-1.11.0
From the output, it looks like cmake is finding the various components correctly:
-- Found Eigen version 3.2.8: /usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/eigen3
Disabling the use of Eigen as a sparse linear algebra library.
This does not affect the covariance estimation algorithm
which can still use the EIGEN_SPARSE_QR algorithm.
-- Building without LAPACK.
-- Building without SuiteSparse.
-- Building without CXSparse.
Compiling without any sparse library: SuiteSparse, CXSparse
& Eigen (Sparse) are all disabled or unavailable. No sparse
linear solvers (SPARSE_NORMAL_CHOLESKY & SPARSE_SCHUR)
will be available when Ceres is used.
-- Google Flags disabled; no tests or tools will be built!
-- Found Google Log header in: /usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include
-- Building without OpenMP (disabling multithreading).
-- Looking for C++ include unordered_map
-- Looking for C++ include unordered_map - found
-- Performing Test HAVE_UNORDERED_MAP_IN_STD_NAMESPACE
-- Performing Test HAVE_UNORDERED_MAP_IN_STD_NAMESPACE - Success
-- Found unordered_map/set in std namespace.
-- Looking for C++ include memory
-- Looking for C++ include memory - found
-- Performing Test HAVE_SHARED_PTR_IN_STD_NAMESPACE
-- Performing Test HAVE_SHARED_PTR_IN_STD_NAMESPACE - Success
-- Found shared_ptr in std namespace using <memory> header.
-- Building Ceres as a static library.
-- Enabling CERES_NO_LAPACK in Ceres config.h
-- Enabling CERES_NO_SUITESPARSE in Ceres config.h
-- Enabling CERES_NO_CXSPARSE in Ceres config.h
-- Enabling CERES_NO_THREADS in Ceres config.h
-- Enabling CERES_STD_UNORDERED_MAP in Ceres config.h
-- Build the examples.
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
-- Build files have been written to: /home/philmass/ceres/build
####Now, compile
make -j 4 > buildoutput.txt
Ceres compilation fails about 75% of the way through, and I get a number of errors that look like:
In file included from /usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/c++/7.3.0/vector:69:0,
from /home/philmass/ceres/ceres-solver-1.11.0/internal/ceres/compressed_row_sparse_matrix.h:34,
from /home/philmass/ceres/ceres-solver-1.11.0/internal/ceres/compressed_row_sparse_matrix.cc:31:
/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/c++/7.3.0/bits/vector.tcc: In member function ‘void std::vector<_Tp, _Alloc>::_M_fill_insert(std::vector<_Tp, _Alloc>::iterator, std::vector<_Tp, _Alloc>::size_type, const value_type&) [with _Tp = double; _Alloc = std::allocator]’:
/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/c++/7.3.0/bits/vector.tcc:458:5: note: parameter passing for argument of type ‘std::vector::iterator {aka __gnu_cxx::__normal_iterator >}’ changed in GCC 7.1
The buildoutput.txt file is attached. link text
2 questions:
Is there some additional setting I need to add for the 2.8 build vs the 2.7 build to make Ceres compilation work?
Is there a better way to cross compile Ceres with the new SDK setup in 2.8, as opposed to the toolchain.cmake file? It’s moderately cumbersome to re-edit all of the SDK paths in that file and try to get them right.
Thanks,
