The error message you’re encountering, “no route to host,” typically suggests a network connectivity issue between your device and the Docker registry. Here are some steps you can take to troubleshoot and potentially resolve this issue:
Network Configuration: Double-check that your device is properly connected to the network. Ensure that the network settings, such as IP address, gateway, and DNS, are correctly configured.
Test Connectivity: Use tools like
pingortracerouteto test connectivity to external servers. For instance, tryping google.comto verify internet access. -
DNS Resolution: Confirm that your device can resolve domain names. You can test this by using the
nslookupordigcommand to resolveregistry-1.docker.io. -
Firewall and Security Settings: Ensure there are no firewall rules or security settings blocking outbound connections on port 443 (HTTPS).
IPv6 Configuration: The error message includes an IPv6 address. If your network does not support IPv6, you might need to disable it or ensure proper configuration. This can be done by editing network settings or using the
sysctlcommand to disable IPv6 temporarily. -
Proxy Settings: If your network uses a proxy, make sure your device is configured to use it. You can set proxy settings in the Docker configuration or system-wide.
Docker Configuration: Verify that Docker is correctly configured on your device. Check the Docker daemon logs for any additional error messages that might provide more context.
If these steps do not resolve the issue, consider testing the network connection from another device on the same network to rule out device-specific problems.
I hope this helps you resolve the issue. If you have any further questions, feel free to ask.
GPU performance in Chromium container on Torizon OS iMX8M-Plus.
