Hello:
BSP: Toradex BSP v2.4
Board: Colibri Solo IMX6 256MB
After generate and install the toolchain , I would like to keep my toolchain updated .
So I’m following the documentation: Yocto Project Application Developer's Guide
But after the opkg-cl , only the packages from /deploy//ipk/all are available to install in my toolchain (I’m using the same base-conf_sdk.conf in my board and works very well)
source /usr/local/oecore-x86_64/environment-setup-armv7at2hf-vfp-neon-angstrom-linux-gnueabi
opkg-cl -f ~/tmp/base-feed_sdk.conf --add-arch armv7at2hf-vfp-neon -o $OECORE_TARGET_SYSROOT update
#base-feed_sdk.conf
src/gz all http://192.168.21.83:8080/oe-core/build/out-glibc/deploy/ipk/all/
src/gz colibri-imx6 http://192.168.21.83:8080/oe-core/build/out-glibc/deploy/ipk/colibri_imx6
src/gz armv7at2hf-vfp-neon http://192.168.21.83:8080/oe-core/build/out-glibc/deploy/ipk/armv7at2hf-vfp-neon/
src/gz armv7at2hf-vfp-neon-mx6qdl http://192.168.21.83:8080/oe-core/build/out-glibc/deploy/ipk/armv7at2hf-vfp-neon-mx6qdl/
src/gz x86_64-nativesdk http://192.168.21.83:8080/oe-core/build/out-glibc/deploy/ipk/x86_64-nativesdk/
I’m trying to add an arch using --add-arch armv7at2hf-vfp-neon but had no effect.
What I’m doing wrong?
Thank you!
Caio Pereira
