Hi all, @andrecurvello.tx and @gustavo.tx,
I think @gauravks has reported this directly but I thought it would be worth a forum post to share. Might be a good place to accumulate information as well.
It looks like an update to docker-compose has made the combination of network host and port mappings an error when it just used to be a warning. This breaks our debug build as require network host to use the CAN bus interfaces and the extension maps port 6502 internally. The message reported is:
[03-13 16:12:06.579] Restarting application container...
[03-13 16:12:06.756] Docker exception: "host" network_mode is incompatible with port_bindings
device:06760593
[03-13 16:12:06.756] Remote docker exception.
The debugger then attempts to connect but gets stuck and seems to stay running but is not connected and the container doesn’t start.
A release build does work and the release container will run. I was unable to run a debug container at the command line as it could not seem to map the application folder but that could be an error in my run command.
I will check with Gaurav who he spoke to but this is a critical problem for us. We are building right now to do deployments in 2 weeks. I need the debug setup to work.
A few questions from me:
- Where did the update occur? Is this a new version of the extension that does an update inside the build container? I can’t see anything here that indicates it should have happened. We are both on v1.3.115 early access. Can we roll back to v1.2 to fix it?
- Is there a workaround we can apply to remove the 6502 port allocation?
- Is there a way to fix the version of the build system we are using? It is a disaster to get an update we are not expecting that breaks everything.
Ed
