I have updated ubuntu version from 14.04 to 16.04 using this reference from NVIDIA:
is it okay to update it like this?
what about RAM problems? can affect the behavior of my system ( turned off unexpectedly) ?
I faced it once to shutdown unexpectedly i thought it was a heat issue since the ubuntu update took two hours almost.
We only have an article about installing 14.04: Installing NVIDIA JetPack with L4T on Apalis TK1. We never updated to Ubuntu 16.04.
Why do you need to update the OS?
Hi Jaski,
I am facing problems with ubuntu 14.04 while installing packges like gstreamer1.0-libav
it tells that no candidate source is available for this package.
also i want to use glade tools to build my GUI for GTK.
so i need an image for TK1 that supports these packages + GUI tools " glade"
We are currently using Ubuntu 18.04 on some TK1 boards and it runs without problems. After some testing we have found that the easiest way is to reinstall L4T 14.04, then run do-release-upgrade. This will update to Ubuntu 16.04 and then run again do-release-upgrade. After that you will be on Ubuntu 18.04 and there you can run chown root / and apt-get -f install.
Finally, you also need to reinstall base files for Ubuntu 18.04 and add universe repository.
After that you will get Ubuntu 18.04 that runs trouble free.
