Update fails many times from Torizon clouad
Hi @tarekmhnds !
This is a modification that Microsoft did (Docker → Container Tools) that is generating some headaches. Even though both are available, the Docker one is now (as of today, in fact) dependent on Container Tools and this is breaking stuff like docker.* not existing anymore.
Could you please downgrade your Docker extension to version 1.29.6 and try again?
Here are some screenshots to serve as a guide.
If Docker extension from Microsoft is already installed:
If Docker extension from Microsoft is not already installed:
Then select the version 1.29.6:
Then trigger a Reload Window.
