Note: Without a local media there is
currently no way to provide the
Installer with a custom URL. There
exists a workaround documented further
below.
But afterwards it creates a new header with named
Custom Image Server without Local Media
I am trying to flash image productions collectively by just using ethernet. Is there a contradiction or a point that i missed?
By the way there tutorial mentions about this:
The Toradex Easy Installer can be used to flash images from an HTTP web server. Using a configuration file as described in the Configuration Format chapter in the Configuration Files tab the Toradex Easy Installer can read the images from a custom/local URL.
There is a configuration file that named “tezi_config.json” which is mention about here.
I made everything also used local media which includes “tezi_config.json” but at the end when it boots nothing happens. Why it should be? Thank you very much for your time and patience..
If I understood you right, you need to setup your environment for flashing your modules through Toradex Easy Installer referencing images in a local server, right?
As you said i followed Unattended flashing over Ethernet but couldn’t handle the issue. I am going to summarize what i have done until now. I make everything that mentioned in there, additionally since it says
When you say that you boot Toradex and nothing happens, please describe it in detail.
The board doesn’t go to Easy Installer? The expected images don’t appear in the Easy Installer list? What is the issue here?
By the way I am using windows and virtual Ubuntu machine on it. Is this the reason of failure?
About the Virtual Ubuntu Machine, is it the one with the HTTP server acting as a “server” for the Easy Installer?
If that is the case, there is a chance that your Virtual Machine may not be exposing ports, addresses, etc.
