Goodmorning,
I trying to get a linux image with x11 support on a imx7d colibri board. I’m building successfully core-image-x11 image recipe in the yocto enviroment. I succesfully booted the image but after login x11 server does not start furthermore I do not have startx nor xinit commands and xhost giving me this error:
xhost: unable to open display ":0.0"
I think I am missing something in the configuration of the image, can you please help me?
This is my current “conf/distro.mydistro.conf” setup
require conf/distro/tdx-x11-upstream-rt.conf
DISTRO_FEATURES:append = " x11"
DISTRO_FEATURES:remove = " wayland pulseaudio wifi 3g nfc alsa bluetooth"
MACHINE_FEATURES:remove = " alsa touchscreen wifi bluetooth 3g qemu-usermode"
Regards
Francesco
Hello @franz-retfie,
Welcome to the Toradex Community!
I see you using the tdx-x11-upstream-rt.conf
distro as a base.
Do you need the PREEMPT-RT patches?
If not, for the Colibri iMX7 on BSP 6 it would be recommended to use the tdx-x11-upstream.conf
distro as a base for your custom distro.
There is also no need to add x11
or remove wayland
from the distro features, this is already done in the tdx-x11.conf
file, which is used by all tdx-x11
distros.
You are also building the core-image-x11
, which is not a supported target.
It would be recommended to use one of the Toradex Reference images.
In this case, the tdx-reference-multimedia-image
would be a good starting point.
With this image working, you can remove what you don’t need for it and create your custom image.
Bruno
thank you for the suggestions.
I was able to start x11 using tdx-x11-upstream-rt.conf
and tdx-reference-multimedia-image
as you suggested. I didn’t say that in the initial post but I need the PREEMPT-RT patches so I’m using the -rt
conf.
However I did find another problem during the process: I found a wrong setting in /etc/X11/xorg.conf
, so I changed it to this:
Section "Device"
Identifier "i.MX Accelerated Framebuffer Device"
Driver "fbdev"
Option "fbdev" "/dev/fb0"
Option "SyncDraw" "false"
EndSection
Thanks for sharing this information.
Bruno
