Unable to start the Toradex Easy install on “Colibri iMX8QXP V1.0B” (using Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth and Iris bord 2.0 A) using ubuntu 20.4 Virtual Box.
I have performed below Steps :
- Connect the board to PC via DVI
interface. - Connect Ethernet
- Select “Colibri-iMX8X_ToradexEasyInstaller_2.0b4-20191231” Image from on Toradex Easy Install Screen.
- Loaded until 99%.
- Waited for 10 minutes.
- Restarted Iris board.
After powering on, as mentioned in start guide. I didn’t see any Toradex Easy Installer setup on my monitor by default → Empty Monitor Screen.
So I tried to use Recovery Mode.
- Make sure the board is turned off.
- Connect the 2 pads (Pins 1 and 2 from JP1) as shown in the video.
- Removed pads as in Step2.
- Run the windows Script.
- Below Screen - [1]: https://share.toradex.com/7iaaye94vbm7egi?direct
From this point, Reboot the Iris board. However Empty Display.
Unable to connect Serial Console with Toradex Computer Modules via Minicom / gtkTerm.
I already copied the yocto image in the SD Card.
I would like to install this yocto image via Toradex Easy install screen.
Please advise.
