I already tried that but I get the following output:
root@colibri-imx7:~# opkg install tzdata-asia
Installing tzdata-asia (2017c) on root
Downloading http://feeds.toradex.com/angstrom/feeds/v2017.12/ipk/glibc/all/tzdata-asia_2017c-r0.0_all.ipk.
To remove package debris, try `opkg remove tzdata-asia`.
To re-attempt the install, try `opkg install tzdata-asia`.
Installing adwaita-icon-theme-symbolic (3.24.0) on root
Downloading http://feeds.toradex.com/angstrom/feeds/v2017.12/ipk/glibc/all/adwaita-icon-theme-symbolic_3.24.0-r0.0_all.ipk.
Configuring adwaita-icon-theme-symbolic.
Collected errors:
* check_data_file_clashes: Package tzdata-asia wants to install file /usr/share/zoneinfo/Asia/Bangkok
But that file is already provided by package * tzdata
So I removed tzdata and tried again. Not working.
root@colibri-imx7:~# opkg remove tzdata
Removing tzdata (2018f) from root...
Installing tzdata (2017c) on root
Downloading http://feeds.toradex.com/angstrom/feeds/v2017.12/ipk/glibc/all/tzdata_2017c-r0.0_all.ipk.
Configuring tzdata.
root@colibri-imx7:~# timedatectl set-timezone "Asia/Kolkata"
Failed to set time zone: Invalid time zone 'Asia/Kolkata'
root@colibri-imx7-emmc:~# timedatectl set-timezone "Asia/Kolkata"
Local time: Mon 2020-01-06 21:36:07 IST
Universal time: Mon 2020-01-06 16:06:07 UTC
RTC time: Mon 2020-01-06 16:06:08
Time zone: Asia/Kolkata (IST, +0530)
Network time on: yes
NTP synchronized: yes
RTC in local TZ: no
root@colibri-imx7-emmc:~# uname -a
Linux colibri-imx7-emmc 4.9.166-2.8.6+gd899927728be #1 SMP Mon Apr 1 13:16:28 UTC 2019 armv7l GNU/Linux
I got it to work. I had to remove tzdata first because it causes clashes at “Bangkok”. I also had to remove tzdata-asia, since it had been installed incorrectly in the earlier attempts. This was my problem. After ensuring that both had been removed, the rest worked as expected.
