Hello Team,
We purchased the i.MX95 V1.3A boards in October 2025, and they have been functioning correctly across multiple assignments and use cases since then.
However, starting yesterday, we have encountered an issue with one of the boards. The board is currently not booting with any of the images we flash. Specifically:
No boot logs are observed on the serial console.
The issue persists across multiple images.
The board is still detected on the host machine when using the UUU tool.
Flashing appears to complete, but there is no visible output or system bring-up post flashing.
We have already performed initial troubleshooting steps, including testing with different assignments and configurations, but the issue remains unresolved.
For your reference, we have attached the purchase invoice.
We request your support in diagnosing and resolving this issue at the earliest. Please let us know if any additional logs, debug steps, or hardware checks are required from our side.
Thank you for your assistance.
Below are steps we tried:
admin:~/mfgtools/build$ sudo uuu -lsusb
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.243-5-g124d086 Connected Known USB Devices Path Chip Pro Vid Pid BcdVersion Serial_no ==================================================================== 3:3 MX95 SDPS: 0x1FC9 0x015D 0x0001 DA76A714E898***
admin:~/imx-build/bld-xwayland/tmp/deploy/images/imx95-19x19-verdin$ sudo uuu -b spl imx-boot
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.243-5-g124d086 Success 1 Failure 0 3:3-DA76A714 4/ 4 [Done ] SDPV: done
But we are not getting boot logs.:
So we kindly request you to help on this as we are working on some critical delivery.
Siddhartha V
