Dear Community,
I’m working to get the CAN enabled on my Colibri iMX6DL using an Aster carrier board. I did the following:
Got the Linux Kernel with git clone -b toradex.x_4.14_2.0.x-imx git://git.toradex.com/linux-toradex.git
Got the toolchain gcc-arm-8.2-2019.01-x86_64-arm-linux-genueabihf.tar.xz
Set the environment variables ARCH=arm
and CROSS_COMPILE=arm-linux-gnueabihf-
Set the default configuration make colibri_imx6_defconfig
and make dtbs
I did as explained here. These are the results of the git diff > changes.txt
+++ b/home/ec/linux-toradex/arch/arm/boot/dts/imx6dl-colibri-aster.dts
@@ -76,6 +76,14 @@
status = “okay”;
+&can1 {
+&can2 {
&ecspi4 {
fsl,spi-num-chipselects = <2>;
cs-gpios = <
@@ -140,10 +148,9 @@
pinctrl-0 = <
&pinctrl_weim_gpio_1 &pinctrl_weim_gpio_2
&pinctrl_weim_gpio_3 &pinctrl_weim_gpio_4
+++ b/home/ec/linux-toradex/arch/arm/boot/dts/imx6qdl-colibri.dtsi
@@ -596,8 +596,8 @@
pinctrl_gpio_2: gpio-2 {
fsl,pins = <
@@ -646,15 +646,15 @@
pinctrl_flexcan1: flexcan1grp {
fsl,pins = <
MX6QDL_PAD_GPIO_7__FLEXCAN1_TX PAD_CTRL_HYS_PU
MX6QDL_PAD_GPIO_8__FLEXCAN1_RX PAD_CTRL_HYS_PU
pinctrl_flexcan2: flexcan2grp {
fsl,pins = <
@@ -1080,4 +1080,3 @@
Compile the device tree with make dtbs
or make imx6dl-colibri-aster.dtb
and I get the following:
ec@ec:~/linux-toradex$ make imx6dl-colibri-aster.dtb
CHK scripts/mod/devicetable-offsets.h
DTC arch/arm/boot/dts/imx6dl-colibri-aster.dtb
Error: arch/arm/boot/dts/imx6qdl-colibri.dtsi:649.30-31 syntax error
FATAL ERROR: Unable to parse input tree
scripts/Makefile.lib:317: recipe for target ‘arch/arm/boot/dts/imx6dl-colibri-aster.dtb’ failed
make1: *** [arch/arm/boot/dts/imx6dl-colibri-aster.dtb] Error 1
arch/arm/Makefile:343: recipe for target ‘imx6dl-colibri-aster.dtb’ failed
make: *** [imx6dl-colibri-aster.dtb] Error 2`
The syntax error refers to the following line: MX6QDL_PAD_GPIO_7__FLEXCAN1_TX PAD_CTRL_HYS_PU
Any recommendations for this error? Thank you.
Kind regards.
Hi @cae30989
First of All, for Bsp 2.8 the Kernel 4.9.2.3 is used and for Bsp 3.0 the Kernel 4.14.x.
Being said that, if you compile device-tree in the kernel branch 4…14.x, then you are not allowed to use any defines for the PAD Settings, since these does not exist any-more. These were deleted to the fact, that we are continuously adapting the device tree and kernel config to the mainline kernel.
Thus I would recommend you to use the value 0x1b0b0
instead of the #define PAD_CTRL_HYS_PU 0x1b0b0
Hi @jaski.tx,
thank you very much for the extended answer. I did as you recommended:
fsl,pins = <
MX6QDL_PAD_GPIO_7__FLEXCAN1_TX 0x1b0b0
MX6QDL_PAD_GPIO_8__FLEXCAN1_RX 0x1b0b0
fsl,pins = <
MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX 0x1b0b0
MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX 0x1b0b0
fsl,pins = <
// MX6QDL_PAD_GPIO_7__GPIO1_IO07 0x1b0b0
// MX6QDL_PAD_GPIO_8__GPIO1_IO08 0x1b0b0
The compilation works.
ec@ec:~/linux-toradex$ make dtbs
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
CHK include/generated/bounds.h
CHK include/generated/timeconst.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
DTC arch/arm/boot/dts/imx6dl-colibri-cam-eval-v3.dtb
DTC arch/arm/boot/dts/imx6dl-colibri-eval-v3.dtb
DTC arch/arm/boot/dts/imx6dl-colibri-iris.dtb
DTC arch/arm/boot/dts/imx6dl-colibri-iris-v2.dtb
I added the imx6dl-colibri-aster.dtb file to the Colibri-iMX6_LXDE-Image-Tezi_2.8b6.184
and installed it via Toradex Easy Installer. Everything so far was good. When I turned on the module I set the fdt_file with the imx6dl-colibri-aster.dtb and boot it using minicom. The following came:
U-Boot 2016.11-2.8.6+g83a53c1c0c (Apr 01 2019 - 09:53:19 +0000)
CPU: Freescale i.MX6DL rev1.3 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 512 MiB
PMIC: device id: 0x10, revision id: 0x21, programmed
MMC: FSL_SDHC: 0, FSL_SDHC: 1
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6 DualLite 512MB V1.1A, Serial# 05174500
Net: using PHY at 0
FEC [PRIME]
Colibri iMX6 # env set fdt_file imx6dl-colibri-aster.dtb
Colibri iMX6 # boot
Booting from internal eMMC chip...
reading imx6dl-colibri-aster.dtb
** Unable to read file imx6dl-colibri-aster.dtb **
reading zImage
** Unable to read file zImage **
emmcboot failed
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1...
starting USB...
USB0: Port not available.
USB1: USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
scanning usb for ethernet devices... 0 Ethernet Device(s) found
USB device 0: unknown device
BOOTP broadcast 1
DHCP client bound to address 192.168.0.21 (3 ms)
Using FEC device
TFTP from server 192.168.10.1; our IP address is 192.168.0.21; sending through gateway 192.168.0.250
Filename 'boot.scr.uimg'.
Load address: 0x17000000
Loading: T T T T T T T T T T
I’m not sure what went wrong here.
Thank you, best regards.
HI
This is U-Boot from Bsp 2.8, but you compiled the devicetree for Bsp 3.0. Could you stick to one version and mix these versions.
reading zImage
Could you check if these files are present in the boot partition of the SoM?
Hi @jaski.tx,
these versions
Do you mean I should just take the branch toradex_4.9-2.3.x-imx
from the Linux-Kernel?
SoM?
I’m sorry I don’t know what command to use to find out this information on the board.
Thanks, best regards.
HI
Do you mean I should just take the branch toradex_4.9-2.3.x-imx from the Linux-Kernel?
Yes.
The easiest is to use the UMS Method from U-Boot.
Hi @jaski.tx,
I cloned the toradex_4.9-2.3.x-imx branch from the Linux Kernel. I followed all the steps.
@@ -81,6 +81,14 @@
+&can1 {
+ status="okay";
+&can2 {
+ status="okay";
&ecspi4 {
cs-gpios = <
@@ -145,10 +153,9 @@
pinctrl-0 = <
- &pinctrl_weim_gpio_5 &pinctrl_weim_gpio_6
+ &pinctrl_weim_gpio_5
&pinctrl_csi_gpio_1
&pinctrl_gpio_1
- &pinctrl_gpio_2
&pinctrl_usbh_oc_1 &pinctrl_usbc_id_1
@@ -465,14 +465,14 @@
fsl,pins = <
- MX6QDL_PAD_GPIO_7__FLEXCAN1_TX 0x80000000
- MX6QDL_PAD_GPIO_8__FLEXCAN1_RX 0x80000000
+ MX6QDL_PAD_GPIO_7__FLEXCAN1_TX PAD_CTRL_HYS_PU
+ MX6QDL_PAD_GPIO_8__FLEXCAN1_RX PAD_CTRL_HYS_PU
fsl,pins = <
- MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX 0x80000000
- MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX 0x80000000
+ MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX PAD_CTRL_HYS_PU
+ MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX PAD_CTRL_HYS_PU
@@ -492,8 +492,8 @@
fsl,pins = <
- MX6QDL_PAD_GPIO_7__GPIO1_IO07 PAD_CTRL_HYS_PU
- MX6QDL_PAD_GPIO_8__GPIO1_IO08 PAD_CTRL_HYS_PU
+ // MX6QDL_PAD_GPIO_7__GPIO1_IO07 PAD_CTRL_HYS_PU
+ // MX6QDL_PAD_GPIO_8__GPIO1_IO08 PAD_CTRL_HYS_PU
@@ -1084,4 +1084,3 @@
#size-cells = <1>;
status = "disabled";
But again I become the same error
Reset cause: POR
I2C: ready
DRAM: 512 MiB
In: serial
Out: serial
Err: serial
Net: using PHY at 0
FEC [PRIME]
Colibri iMX6 # boot
reading zImage
emmcboot failed
Scanning mmc 0:1...
starting USB...
USB1: USB EHCI 1.00
BOOTP broadcast 1
Using FEC device
I checked the output of ums 0 mmc 0
in the u-boot console:
UMS: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x748000
and it kind of gets stuck there.
Best regards.
HI
I checked the output of ums 0 mmc 0 in the u-boot console: UMS: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x748000 / and it kind of gets stuck there.
You should see two extra partitions on your host, the boot partition and root filesystem partition. Check if the files mentioned files above are present in Boot partition.
Hi @jaski.tx,
unfortunately I don’t have two extra partitions on my host computer. I guess I’m making a mistake when I put everything into the Toradex Easy Installer. I’ll try again.
Best regards.
Hi @jaski.tx,
when I run make dbts
does it affect the zImage?
No. Anyway you did not change the kernel, so you don’t need to flash a new one.
I would recommend you to start over and just change the new custom device-tree.
Hi @jaski.tx,
I finally got it to work. I’m very thankful for your help! I started all over and only changed the new custom device-tree.
My last question regarding this topic is, would I always have to set the fdt_file to imx6dl-colibri-aster.dtb or is there a way to make this a default value?
Thanks, kind regards.
Perfect that it works.
You can change the variable’s value and save the Environment by the saveenv
command. This should keep the value.
If you want to fix it when you flash the complete image, then you should use a U-Boot Environment file as described here.
