We are trying to install the laser sensor package using below command:
“pip install VL53L1X”
And encountering error, is listed below.
Installing collected packages: VL53L1X
Running setup.py install for VL53L1X … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python -u -c ‘import sys, setuptools, tokenize;
sys.argv[
0] =
‘"’"’/tmp/pip-install-TCwvOX/vl53l1x/setup.py’“'”‘;
file=’“'”'/tmp/pip-
install-TCwvOX/vl53l1x/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’"',
open)(_
file_);code=f.read().replace(‘"’“‘\r\n’”‘"’,
‘"’“‘\n’”‘"’);f.close();exec(comp
ile(code, file, ‘"’“‘exec’”‘"’))’ install --record
/tmp/pip-record-dpc483/in
stall-record.txt --single-version-externally-managed --compile
–install-headers
/usr/include/python2.7/VL53L1X
cwd: /tmp/pip-install-TCwvOX/vl53l1x/
Complete output (22 lines):
/usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown
distribution
option:
‘long_description_content_type’
warnings.warn(msg)
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-2.7
copying python/VL53L1X.py → build/lib.linux-armv7l-2.7
running build_ext
building ‘vl53l1x_python’ extension
creating build/temp.linux-armv7l-2.7
creating build/temp.linux-armv7l-2.7/api
creating build/temp.linux-armv7l-2.7/api/core
creating build/temp.linux-armv7l-2.7/api/platform
creating build/temp.linux-armv7l-2.7/python_lib
arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon
-mfloat-abi
=hard
-fno-strict-aliasing -O2 -pipe -g -feliminate-unused-debug-types
-fdebug-p
refix-map=/build/jenkins/v2017.12/compile/machine/colibri-vf/build/tmp-angstrom-
glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/python/2.7.13-r1=/usr/src/debu
g/python/2.7.13-r1
-fdebug-prefix-map=/build/jenkins/v2017.12/compile/machine/co
libri-vf/build/tmp-angstrom-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/py
thon/2.7.13-r1/recipe-sysroot-native=
/compile/machine/colibri-vf/build/tmp-angstrom-glibc/work/armv7at2hf-neon-angstr
om-linux-gnueabi/python/2.7.13-r1/recipe-sysroot= -DNDEBUG -g -O3 -Wall
-Wstrict
-prototypes -fPIC -I.
-Iapi/core -Iapi/platform -I/usr/include/python2.7 -c api/
core/vl53l1_api_calibration.c -o
build/temp.linux-armv7l-2.7/api/core/vl53l1_api
_calibration.o -std=c99
/usr/lib/gcc/arm-angstrom-linux-gnueabi/7.2.0/../../../../arm-angstrom-linux
-gnueabi/bin/as: error while loading
shared libraries: libbfd-2.29.0.20170912.so
: cannot open shared object file: No such file or directory
api/core/vl53l1_api_calibration.c:875:1: fatal error: error writing
to -: Br
oken pipe
compilation terminated.
error: command ‘arm-angstrom-linux-gnueabi-gcc’ failed with exit
status 1
ERROR: Command errored out with exit status 1: /usr/bin/python -u -c
‘import sys
sys.argv[0] = ‘"’"’/tmp/pip-install-TCwvOX/vl53l1x/setup
.py'"'"';
file=‘"’“‘/tmp/pip-install-TCwvOX/vl53l1x/setup.py’”‘"’;f=getattr(
tokenize, '"'"'open'"'"',
open)(file);code=f.read().replace(‘"’“‘\r\n’”‘"’,
'"'"'\n'"'"');f.close();exec(compile(code, __file__,
-record
/tmp/pip-record-dpc483/install-record.txt --single-version-externally-ma
naged --compile --install-headers
/usr/include/python2.7/VL53L1X Check the logs
for full command output.
Following are the software specification:
- linux version
Linux colibri-imx7-emmc 4.9.220-2.8.7+g57229263ff65 #1 SMP Wed Jun 10
17:21:48 UTC 2020 armv7l GNU/Linux
We have installed “Toradex Embedded Linux Demo with LXDE” image
GCC version -
gcc - 7.2.0-r0.0 - GNU cc and gcc C compilers GNU cc and gcc C compilers.
