I’m using viola plus carrier board
colibri iMX7D emmc SOM
build tdx-multimedia-reference-image
Want to install pyside2 on my image but there is no recipe so i tried to create one but as pyside2 depends upon shiboken2 . So first i need to create shiboken2 recipes but since I’m new to this I’m unable to create one can someone help me is there a proper syntax?? gone through yocto guide regarding create new recipe still i find some difficulties.
I’m using kirkstone branch and setup environment through . export
Any help will be much appreciated as I’m totally new to this kind of stuff
I can understand creating custom recipes inside Yocto can sometimes become difficult and time consuming. May I suggest you to check our TorizonCore OS where you can install package using Debian package manager inside container.
Check below link for detail instruction Qt on Torizon OS | Toradex Developer Center
Once can use Torizon VS code plugin to get started right away using qt template
To test above procedure you will require to install TorizonCore image using Toradex easy installer
I hope this will help you with your development in case you are not looking for this do let us know.
Ritesh Kumar
if you go to the “Downloads files” page of Pyside2 (PySide2 · PyPI) you can see that there are only .whl archives, not tar archives and the Readme file of the script is pretty clear:
Note: “.whl” archive packages are not supported!
so you need to find and URL pointing to the tar or zip version of the package
