It seems that I cannot install libdrm-tests in torizon/weston-am62:4 (I have also tried torizon/qt6-wayland-examples-am62:4 with the same result). Are the versions somehow freezed or TI packages conflicting there?
root@verdin-am62-15478822:/# mkdir -p /var/lib/dpkg /var/cache/apt/archives/partial
apt update
Get:1 http://deb.debian.org/debian bookworm-backports InRelease [59.4 kB]
Get:2 http://deb.debian.org/debian bookworm InRelease [151 kB]
Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
Get:4 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
Get:5 https://feeds.toradex.com/stable/am6x/snapshots/20251217T210750Z stable InRelease [27.4 kB]
Get:6 http://deb.debian.org/debian bookworm-backports/main arm64 Packages [300 kB]
Get:7 http://deb.debian.org/debian bookworm/main arm64 Packages [8691 kB]
Get:8 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [6936 B]
Get:9 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [291 kB]
Get:10 https://feeds.toradex.com/stable/am6x/snapshots/20251217T210750Z stable/non-free arm64 Packages [6696 B]
Get:11 https://feeds.toradex.com/stable/am6x/snapshots/20251217T210750Z stable/main arm64 Packages [45.9 kB]
Fetched 9683 kB in 6s (1667 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
N: Repository 'Debian bookworm' changed its 'non-free component' value from 'non-free' to 'non-free non-free-firmware'
N: More information about this can be found online in the Release notes at: https://www.debian.org/releases/bookworm/arm64/release-notes/ch-information.html#non-free-split
root@verdin-am62-15478822:/# apt install libdrm-tests
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libdrm-tests : Depends: libdrm2 (= 2.4.114-1+b1) but 2.4.123-1~bpo12+1 is to be installed
E: Unable to correct problems, you have held broken packages.
I am using Torizon OS 7.5.0 (Easy Pairing) on Verdin AM62.
