How can I solve this error code received from Upverter when trying to generate BSP?
[ cURL error 28: Operation timed out after 20000 milliseconds with 0 bytes received (see libcurl - Error Codes)]
Could you please outline the steps to reproduce the issue you’re experiencing?
I got a response from Gumstix where I was informed that the Upverter platform cannot generate the BSP of the board I have designed at this time.
