I want to flash new image into my board, however I can no longer access toradex easy installer via VNC (suspect there is no more vnc server running in the existing image). I managed to do it previously.
Hi Jeff,
If you are unable to access the Toradex Easy Installer (Tezi) via VNC, there are a few steps you can take to resolve the issue:
Reload Toradex Easy Installer:
If you have already flashed an OS into your Computer-on-Module, you can reload Tezi into the RAM of the module. This will bring you back to the main graphical user interface, allowing you to easily install an OS image.
You can follow the steps provided in the “Download and Install Toradex Easy Installer Image” section of the documentation to reload Tezi.
Use Alternative Methods to Provide OS Images:
If VNC is not working, you can provide the OS images to Tezi using a USB Flash Drive or an SD card. This way, you can still flash the new image without needing VNC access.
Check Network Configuration:
Ensure that your network configuration is correct and that there are no issues preventing VNC from running. Sometimes, network settings or firewall rules might block VNC access.
Direct Connection:
If possible, connect a display and input devices (keyboard/mouse) directly to the board. This will allow you to interact with the Tezi interface directly without needing VNC.
Enable Toradex CI Feed:
If you want to add more sources to Tezi, you can use the Feeds button to enable the Toradex Continuous Integration Server (testing) option. This might help if you need to update or reinstall Tezi.
If none of these steps resolve the issue, please provide more details about your setup and any error messages you are encountering, and I can assist you further.
[Your Name]
Thanks for the response. Are you able to provide more details about loading the tezi for viola plus carrier board, e.g. recovery mode. The instruction does not cover viola carrier board.
I havent got it working yet. For step 3, there is no additional micro usb port besides the ethernet port for viola carrier board, hence I connect using usb to uart a via the extension connector (X9). Can it works as well?
Anyway, I then tried to load the tezi into the board using a window pc, however it seems unable to detect any known usb device. It only shows “success 0, failure 0, wait for known usb device appear”.
Looking through the recovery-windows README file, I am unable to find “ADB devices”. I am also unable to select “andriod_winusb.inf” using the “from disk” button as well.
By the way, how do I know that I have successfully enter into recovery mode?
