Hi all,
We are using a Colibri T20 board embedded into a custom Key’ Touch Device.
Currently, it is working under WinCE and we expect to migrate it under a linux system with Yocto.
First at all, we’re trying to flash the Toradex example linux images.
- I have downloaded the Colibri_T20_LinuxImageV2.3 image.
I set the board into RecoveryMode and I simply executed:
./update.sh -r 512 -v V1_2
It took few minutes to upload everything. I set the board in nbormal mode. Reboot. Everything works, I got the Linux Angstrom loaded.
- I’ve then downloaded the Colibri_T20_LinuxImageV2.6 (beta) image.
At first glance, I noted that the flashing tool were different. t20_nvflash for the image 2.3 and tegrarcm for the latter.
I had to execute this command:
update.sh -r 512 -v V1_2 -d
I got the following output:
Colibri T20 rootfs detected
bct file: ../colibri-t20_bin/colibri_t20-512-v11-nand.bct
booloader file: ../colibri-t20_bin/u-boot-dtb-tegra.bin
load addr 0x80108000
entry addr 0x80108000
device id: 0x7820
uid: 0x0a7c814842e165d7
RCM version: 2.1
downloading miniloader to target at address 0x40008000 (132976 bytes)...
miniloader downloaded successfully
Chip UID: 0x00000000000000000a7c814842e165d7
Chip ID: 0x20
Chip ID Major Version: 0x1
Chip ID Minor Version: 0x4
Chip SKU: 0x8 (t20)
Boot ROM Version: 0x1
Boot Device: 0x1 (NAND)
Operating Mode: 0x3 (developer mode)
Device Config Strap: 0x0
Device Config Fuse: 0x20
SDRAM Config Strap: 0x0
sending file: ../colibri-t20_bin/colibri_t20-512-v11-nand.bct
- 4080/4080 bytes sent
../colibri-t20_bin/colibri_t20-512-v11-nand.bct sent successfully
sending file: ../colibri-t20_bin/u-boot-dtb-tegra.bin
\ 636532/636532 bytes sent
../colibri-t20_bin/u-boot-dtb-tegra.bin sent successfully
It took 3 or 4 seconds max.
So, I assume that the roofts was not flashed at all.
I reboot the device, and it is still the Linux Image 2.3 that is loaded.
As far as I know, the update.sh script does not have the same behavior at all ?
Have I done something wrong ?
Any idea to flash the linux image correctly ?
Thanks.
K
