Hello Guys,
Recently we bought Colibiri IM6DL 512MB for our company.Our customer has given java jar file and he want to execute particular Jar on this device.When i try to execute jar file in Toradex Linux i am getting error “could not find or load main class”.
I have installed jdk1.8 as per our customer request on Linux,
I am new to java and Linux and i have attached jar file.link text
Hi @vikramh93 and Welcome to the Toradex Community!
Could you provide the version of the Hardware and Software of your module?
Which command did you use to launch the jar file?
I have installed jdk1.8 as per our customer request on Linux.
How did you install jdk 1.8?
Hello @jaski.tx ,
I have installed Toradex Linux embedded through easy installer and java jdk1.8.0_231 manually by using update-alternatives --install command by using below guide link text
I am using java -jar SampeApp.jar command to execute,
Module: Col IMX6Dl 512MB IT
Hi
Thanks for your Input. You need to install Java for Arm.
I have installed Linux ARM 32 Hard Float ABI version in java. To verify i have used java -version command to see output.
Is it possible to change OS from toradex Linux to torizon OS? Previously i was able to change OS from wince to Linux by using easy installed,now i am having difficulty to change OS.
HI @vikramh93
Yes, it’s possible by using Toradex Easy Installer. Which difficulties are you having?
Could you share some error log?
Hello @jaski.tx ,
Thanks for the help.I was able to install open jdk 11 and jar got executed.
