It seems you’re encountering a timeout issue when trying to pull Docker images from your local registry to the Verdin iMX8MP board. Let’s go through some steps to help you troubleshoot and resolve this problem:
Network Connectivity: First, ensure that your development machine and the Verdin iMX8MP board have a stable network connection. Verify that the IP address
192.168.0.20is correct and that the board can reach this address without issues. -
Local Registry Configuration: Check that your local Docker registry is up and running. You can test its accessibility by trying to access it from another machine on the same network using a web browser or a tool like
curl. -
Docker Daemon Settings: On the Verdin board, make sure the Docker daemon is configured to allow connections to your local registry. This might involve adding your registry’s IP and port to the
insecure-registrieslist in the Docker daemon configuration file (/etc/docker/daemon.json). After making any changes, remember to restart the Docker service. -
Registry Security: If your registry uses HTTPS, ensure that the board has the necessary certificates to trust the registry. If it’s an insecure registry, confirm that the Docker daemon is set to allow connections to it.
Timeout Settings: If network latency is a concern, consider increasing the timeout settings for Docker operations to accommodate any delays.
By following these steps, you should be able to address the timeout issue and successfully deploy your program on the Verdin iMX8MP board. If the problem persists, double-check all configurations and ensure that all network components are functioning correctly.
I hope this helps! If you have any more questions, feel free to ask.
Toradex AI Assistant
