#5 [newcsharp-debug 2/5] RUN apt-get -q -y update && apt-get -q -y install openssl openssh-server rsync file && apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
#5 CACHED
#6 [newcsharp-debug 3/5] RUN apt-get -q -y update && apt-get -q -y install libgpiod2:arm64 libgpiod-dev:arm64 && apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
#6 CACHED
#7 [newcsharp-debug 4/5] RUN mkdir /var/run/sshd && sed ‘s@session\srequired\spam_loginuid.so@session optional pam_loginuid.so@g’ -i /etc/pam.d/sshd && if test torizon != root ; then mkdir -p /home/torizon/.ssh ; else mkdir -p /root/.ssh ; fi && echo “PermitUserEnvironment yes” >> /etc/ssh/sshd_config && echo “PermitRootLogin yes” >> /etc/ssh/sshd_config && echo “Port 2222” >> /etc/ssh/sshd_config && echo “PasswordAuthentication yes” >> /etc/ssh/sshd_config && echo “PermitEmptyPasswords yes” >> /etc/ssh/sshd_config && su -c “env” torizon > /etc/environment && echo “torizon:” | chpasswd -e
#7 CACHED
#8 [newcsharp-debug 5/5] RUN rm -r /etc/ssh/ssh*key && dpkg-reconfigure openssh-server
#8 CACHED
#9 [newcsharp-debug] exporting to image
#9 exporting layers done
#9 writing image sha256:295bf10482c230137066673c69af23ed1159bc2778bc3504a6adf7622bfcc505 done
#9 naming to localhost:5002/newcsharp-debug:arm64 done
#9 DONE 0.0s
#10 [newcsharp-debug] resolving provenance for metadata file
#10 DONE 0.0s
Terminal will be reused by tasks, press any key to close it.
Executing task: DOCKER_HOST= docker compose --ansi never push newcsharp-debug
WARN[0000] The “DOCKER_LOGIN” variable is not set. Defaulting to a blank string.
WARN[0000] /home/Torizon/Csharpsensor/docker-compose.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion
Pushing localhost:5002/newcsharp-debug:arm64: fe03705a2994 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 89db35b19ef7 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: ac335645c4c2 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 9301d1299ba5 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 550e01653322 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 85c261c6b451 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: bba027968eee Preparing
Pushing localhost:5002/newcsharp-debug:arm64: bb95280742bd Preparing
Pushing localhost:5002/newcsharp-debug:arm64: d5661228a6f6 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 1f74cca9ef3c Preparing
Pushing localhost:5002/newcsharp-debug:arm64: cf08845a6a01 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: e009595c7dc0 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 6dc89911362e Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 0d7dccc6d0e7 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 67ca54a26679 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 3440d23a444f Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 5a49bdb65752 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: 2bd1a2222589 Preparing
Pushing localhost:5002/newcsharp-debug:arm64: bb95280742bd Waiting
Pushing localhost:5002/newcsharp-debug:arm64: d5661228a6f6 Waiting
Pushing localhost:5002/newcsharp-debug:arm64: 1f74cca9ef3c Waiting
Pushing localhost:5002/newcsharp-debug:arm64: cf08845a6a01 Waiting
Pushing localhost:5002/newcsharp-debug:arm64: 5a49bdb65752 Waiting
Pushing localhost:5002/newcsharp-debug:arm64: 2bd1a2222589 Waiting
Pushing localhost:5002/newcsharp-debug:arm64: e009595c7dc0 Waiting
Pushing localhost:5002/newcsharp-debug:arm64: 6dc89911362e Waiting
Pushing localhost:5002/newcsharp-debug:arm64: 3440d23a444f Waiting
Pushing localhost:5002/newcsharp-debug:arm64: 0d7dccc6d0e7 Waiting
Pushing localhost:5002/newcsharp-debug:arm64: 67ca54a26679 Waiting
Pushing localhost:5002/newcsharp-debug:arm64: bba027968eee Waiting
Pushing localhost:5002/newcsharp-debug:arm64: 550e01653322 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 89db35b19ef7 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 9301d1299ba5 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: ac335645c4c2 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: fe03705a2994 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: bba027968eee Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 85c261c6b451 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: bb95280742bd Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: d5661228a6f6 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: e009595c7dc0 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 1f74cca9ef3c Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 0d7dccc6d0e7 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 6dc89911362e Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: cf08845a6a01 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 67ca54a26679 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 2bd1a2222589 Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 3440d23a444f Layer already exists
Pushing localhost:5002/newcsharp-debug:arm64: 5a49bdb65752 Layer already exists
Executing task: DOCKER_HOST=192.168.0.10:2375 LOCAL_REGISTRY=192.168.0.20 TAG=arm64 GPU=-imx8 DEBUG_SSH_PORT=2222 DEBUG_PORT1= DEBUG_PORT2= DEBUG_PORT3= docker compose --ansi never pull newcsharp-debug
newcsharp-debug Pulling
newcsharp-debug Warning Get “https://192.168.0.20:5002/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
WARNING: Some service image(s) must be built from source by running:
docker compose build newcsharp-debug
1 error occurred:
* Error response from daemon: Get “https://192.168.0.20:5002/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
- The terminal process “/bin/bash ‘-c’, ‘DOCKER_HOST=192.168.0.10:2375 LOCAL_REGISTRY=192.168.0.20 TAG=arm64 GPU=-imx8 DEBUG_SSH_PORT=2222 DEBUG_PORT1= DEBUG_PORT2= DEBUG_PORT3= docker compose --ansi never pull newcsharp-debug’” terminated with exit code: 18.
- Terminal will be reused by tasks, press any key to close it.
The pipe program ‘ssh’ exited unexpectedly with code 255."
