We wanted to create a new carrier board design based on Colibri Evaluation Board template using the https://pinout.torizon.io/#/.
So, we open the URL, click “New from template”, then select “Colibri Evaluation Board” and hit “Open”, the page keeps loading forever as seen in the picture below:-
Please let us know how to proceed here.
Otherwise, please provide XML file for pin configuration of Colibri Evaluation Board, so that we can generate a project with it. Thank you.
Experiencing an issue where the page continuously loads after selecting a template on the Toradex Pinout Designer can be due to several factors, such as browser compatibility issues, network problems, or temporary glitches on the website. Here are a few steps you can take to troubleshoot and potentially resolve the issue:
- Clear Browser Cache and Cookies: Sometimes, outdated cache and cookies can cause loading issues. Clearing them might resolve the problem.
- Try a Different Browser: If the issue persists, try accessing the site using a different web browser. This can help determine if the problem is browser-specific.
- Check Network Connection: Ensure that your internet connection is stable. Sometimes, unstable connections can cause pages to load indefinitely.
- Disable Browser Extensions: Certain browser extensions, particularly ad blockers or script blockers, can interfere with website functionality. Try disabling them temporarily to see if that resolves the issue.
- Use Incognito Mode: Opening the site in an incognito or private browsing window can sometimes bypass issues caused by browser settings or extensions.
Regarding the XML file for the pin configuration of the Colibri Evaluation Board, while I cannot directly provide files or links, the Colibri Evaluation Board’s documentation and resources typically include detailed information about pin configurations and might offer downloadable resources like the XML file you’re seeking. These resources are often found in the developer section of the Toradex website or directly associated with the product documentation.
If the problem persists after trying the above steps, it could be indicative of a more significant issue with the website, which would need to be addressed by the Toradex technical team responsible for the site’s maintenance.
Toradex AI Assistant
Colibri iMX6ULL | Toradex Developer Center.
Hi @rajdeepteck123,
We quickly tried creating for Vf50 and it works here.
Can you please try suggestion by Toradex AI and let us know if you still faces issue.
Best regards
Ritesh Kumar
Hi @ritesh.tx, the online pinout designer still didn’t work for me.
But, I am able to use the offline tool properly, so its fine.
