Unable to Change Boot-UP settings of GPIO in imx7
I want to change boot-up time settings for few GPIO’s so that at bootup i can get the repective GPIO direction and level as i configured.
For that I first try to use the iMX7 GPIO Tool V 1.2 however Boot-up settigs options is disabled in this tool.
Second i tried to configure using command prompt by the method provided in below mentioned links:
https://www.toradex.com/community/questions/40010/gpio-pull-up-seems-not-work-under-eboot-on-colibri.html
But again failed to configure as Save gpio command is not executed on command prompt (“Cannot execute save.exe” coming when I execute save gpio command).
Please guide me to change the boot time configuration of GPIO.
Regards
Bipin Kumar
Dear @bipin7301,
You can edit the Config Block directly in the Bootloader, we already mentioned this on that page : https://developer.toradex.com/knowledge-base/gpio-config-block-settings#Tegra_iMX7_and_Vybrid
You should not try in WinCE Command prompt, you should do that in bootloader commands.
Please let us know if you face any issue on this.
