Having trouble building dunfell-5.x.y -m tdxref/default.xml for Apalis 1.1B for the past week or two. I tried making a new folder and started from scratch following Build a Reference Image with Yocto Project/OpenEmbedded | Toradex Developer Center but still facing problem. Successful build was build on 10/19. After that, tried building last week and it started failing after a repo sync.
I am attaching the log. → link text
Loading cache: 100% |############################################################################################################################################################################################################################################| Time: 0:00:00
Loaded 3989 entries from dependency cache.
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "aarch64-tdx-linux"
MACHINE = "apalis-imx8"
DISTRO = "tdx-xwayland"
DISTRO_VERSION = "5.1.0-devel-20201118014244+build.0"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
meta-toradex-nxp = "HEAD:8536f49558c4f9ef78abcd1569887c24f34138ac"
meta-freescale = "HEAD:176cae6030dff808f22c84e2fd0e5cccc555d5b0"
meta-freescale-3rdparty = "HEAD:05b1746a4adc240b690fe965ac5b8a043d9b9d03"
meta-toradex-tegra = "HEAD:f3d8d8cff00b9fbff920bbd5e5eb1cfdce755290"
meta-toradex-bsp-common = "HEAD:904241286764f371e54f6e6070ecdf41fb6a2700"
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python = "HEAD:2a5c534d2b9f01e9c0f39701fccd7fc874945b1c"
meta-freescale-distro = "HEAD:5d882cdf079b3bde0bd9869ce3ca3db411acbf3b"
meta-toradex-demos = "HEAD:23dcda8b5783cd8a81a989f40a1f515754a059e8"
meta-qt5 = "HEAD:0d8eb956015acdea7e77cd6672d08dce18061510"
meta-toradex-distro = "HEAD:27000bd0282b681ab083430b5e49d81e42ce1f71"
meta-poky = "HEAD:492e345b5e01e59f1f4374388005f81b860db636"
meta = "HEAD:4f395ad49ef9035954d0fda7b7df14dea18b49a0"
meta-virtualization = "dunfell:ff997b6b3ba800978546098ab3cdaa113b6695e1"
Initialising tasks: 100% |#######################################################################################################################################################################################################################################| Time: 0:00:05
Sstate summary: Wanted 2281 Found 0 Missed 2281 Current 1151 (0% match, 33% complete)
NOTE: Executing Tasks
ERROR: linux-toradex-5.4.47+gitAUTOINC+3f945d0d10-r0 do_kernel_metadata: Could not generate configuration queue for apalis-imx8.
ERROR: linux-toradex-5.4.47+gitAUTOINC+3f945d0d10-r0 do_kernel_metadata: Execution of '/media/HD3/PremOS/oe-core/build/tmp/work/apalis_imx8-tdx-linux/linux-toradex/5.4.47+gitAUTOINC+3f945d0d10-r0/temp/run.do_kernel_metadata.22804' failed with exit code 1:
ERROR. input file "cfg/virtio.scc" does not exist
ERROR: could not process input files: /media/HD3/PremOS/oe-core/build/tmp/work/apalis_imx8-tdx-linux/linux-toradex/5.4.47+gitAUTOINC+3f945d0d10-r0/defconfig /media/HD3/PremOS/oe-core/layers/meta-virtualization/recipes-kernel/linux/linux-yocto/xt-checksum.scc /media/HD3/PremOS/oe-core/layers/meta-virtualization/recipes-kernel/linux/linux-yocto/ebtables.scc /media/HD3/PremOS/oe-core/layers/meta-virtualization/recipes-kernel/linux/linux-yocto/vswitch.scc /media/HD3/PremOS/oe-core/layers/meta-virtualization/recipes-kernel/linux/linux-yocto/lxc.scc /media/HD3/PremOS/oe-core/layers/meta-virtualization/recipes-kernel/linux/linux-yocto/docker.scc cfg/virtio.scc
See /tmp/tmp.8A8UXIJXnJ for details
WARNING: exit code 1 from a shell command.
ERROR: Logfile of failure stored in: /media/HD3/PremOS/oe-core/build/tmp/work/apalis_imx8-tdx-linux/linux-toradex/5.4.47+gitAUTOINC+3f945d0d10-r0/temp/log.do_kernel_metadata.22804
Thanks,
Prem
